First of all: great project, keep on going!
I am a long time user of pihole and I am very happy.
Unfortunately after the update to version 6 some things have changed.
Is it possible to add HA support in the feature? I was able to get pihole in HA with gravitysync and keepalived, but since the update, it's no longer working.
### Effective July 26, 2024, this project has been retired. Thank you for your use and enthusiasm for a project that began as a few lines of bash in a Slack channel and envolved into something far more complex, and used by many thousands of Pi-hole enthusiasts over the last four years.
### The last released version of Gravity Sync (4.0.7) should continue to work with Pi-hole 5.x, but not with Pi-hole 6+ due to architecture changes.
This thread discusses home assistant. Not sure if anything has changed since this post but it would something to look at on the Home Assistant forum perhaps.
Keepalived is a VRRP protocol, pretty much every service will work with it, including pi-hole. I'm going to guess your issue's with gravitysync instead.
