I’m still having some issues with group management.
I’ve added clients (IP and MAC) to a disabled group, and removed from the default group. Still seems to get blocked, until I disable all for example 60 min from the top menu.
I must still be missing something here, so would appreciate some ideas to try to fix.
I think I may have found the issue, needing to put a /24 after the IP address for an unblocked client. Not sure why that was needed vs. just the IP address itself. I also had MAC address listed for unblocked and that didn't seem to work.
Will try some more and make sure that was the case,
Separate observation on your regex entries - https: is never part of a domain name, so these entries don't work as you expect. Enter the domain only, then add to the blacklist or whitelist as a wildcard, and Pi-hole will make the correct regex.
IP 101 should be in the Unblocked group. When I added new /24, (looks like I can't edit, so added a new one) it looks like it was also in the Default group in error.
I disabled the Unblocked group, as it seemed like the setting based on when I "disable" PiHole temporarily in main menu. Should I "Enable" the Unblocked group?
I'll try that. I had disabled as it didn't seem like it was working otherwise. I'll go back to removing the /24 and double check the settings and see if I can narrow it down further.
Guess I'm still not sure how it works. For IP 101 I'd like to not have any blocked, so how do I configure that. I was thinking I would disable the unblocked group.
jfb - Back to original debug, if I list IP 101 in Unblocked, it still didn't get to a website that had some ad forwarding. If I add another IP 101/24, then it worked ok. That was the only change I made. Unblocked is Enabled.
I also tried adding a "*" regex to unblock all domains, but that didn't work. Only when I added the /24 did it then get through to the website.
