ESXI 6 -> Debian VM.
cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=debian
HOME_URL="https://www.debian.org/ "
SUPPORT_URL="Debian -- Support "
BUG_REPORT_URL="https://bugs.debian.org/ "
Gravity Update should succeed without Pihole losing network access. Pings to Pihole fails. Have to reboot the VM to get Pihole working.
https://tricorder.pi-hole.net/5ir0nh1abe
What does pihole -g
show before the network drops?
[i] Preparing new gravity database... [✓] Preparing new gravity database
[i] Status: Pending... [✓] Status: Retrieval successful
[i] Received 57461 domains
[i] Target: https://mirror1.malwaredomains.com/files/justdomains
[i] Status: Pending... [✓] Status: No changes detected
[i] Received 0 domains
[i] Target: https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
/////Network Drops.
client_loop: send disconnect: Broken pipe
Is that repeatable, does it die at that same spot every time?
Yes. I can reproduce it all the time . Updating gravity via GUI or CLI kills the network interface and pihole
Any insights from the logs?
Sorry, it always drops with https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
as the list to retrieve?
And you'll need to do a new debug run, the logs are automatically deleted after a time out period.
It stopped crashing for now.
Yes.. it always loses network @
Current Output:
pihole -g
[i] Received 57439 domains
[i] Target: https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
[✓] Storing downloaded domains in new gravity database
[✓] Building tree
[✓] Swapping databases
[i] Number of gravity domains: 57439 (57439 unique domains)
[i] Number of exact blacklisted domains: 0
[i] Number of regex blacklist filters: 2
[i] Number of exact whitelisted domains: 0
[i] Number of regex whitelist filters: 1
[✓] Flushing DNS cache
[✓] Cleaning up stray matter
[✓] DNS service is running
system
Closed
July 25, 2020, 8:13pm
9
