General Error Assistance
Errors during debug, unsure of cause or solutions. My understanding of Docker and pihole are both rather limited, as I’m not very knowledgeable in networking. Decided to run a debug because the admin panel shows “Warning in NTP client:” from about a week ago.
Run on stock Pi5 running Bookworm v.12.
Docker version is 28.5.1. build e180ab8
Docker-compose.yml:
services:
  pihole:
    container_name: pihole
    image: pihole/pihole:latest
    ports:
      # DNS Ports
      - "53:53/tcp"
      - "53:53/udp"
      # Default HTTP Port
      - "80:80/tcp"
      # Default HTTPs Port. FTL will generate a self-signed certificate
      - "443:443/tcp"
      # Uncomment the below if using Pi-hole as your DHCP Server
      #- "67:67/udp"
      # Uncomment the line below if you are using Pi-hole as your NTP server
      #- "123:123/udp"
    environment:
      # Set the appropriate timezone for your location from
      # https://en.wikipedia.org/wiki/List_of_tz_database_time_zones, e.g:
      TZ: 'America/New_York'
      # Set a password to access the web interface. Not setting one will result in a random password being assigned
      FTLCONF_webserver_api_password:
      # If using Docker's default `bridge` network setting the dns listening mode should be set to 'all'
      FTLCONF_dns_listeningMode: 'all'
    volumes:
      # For persisting Pi-hole's databases and common configuration file
      - './etc-pihole:/etc/pihole'
      # Uncomment the below if you have custom dnsmasq config files that you want to persist. Not needed for most starting fresh with Pi-hole v6. If you're upgrading from v5 you and have used this directory before, you should keep it enabled for the first v6 container start to allow for a complete migration. It can be removed afterwards. Needs environment variable FTLCONF_misc_etc_dnsmasq_d: 'true'
      #- './etc-dnsmasq.d:/etc/dnsmasq.d'
    cap_add:
      # See https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
      # Required if you are using Pi-hole as your DHCP server, else not needed
      - NET_ADMIN
      # Required if you are using Pi-hole as your NTP client to be able to set the host's system time
      - SYS_TIME
      # Optional, if Pi-hole should get some more processing time
      - SYS_NICE
    restart: unless-stopped
Unsure if related, but I have noticed a lot of ads getting through where this has not been a previous issue. Could be just a coincidence or my own lack of awareness, but I’m not experiencing any major deviations from expected behavior.
https://tricorder.pi-hole.net/y2M4706Q/
As the host and the Docker containers share the same clock, you can safely disable time syncing in the container:
Pi-hole Settings > System > flip Basic to Expert > All settings > Network Time Sync > ntp.sync.active
Just as long as the Docker host itself is able to sync time.
Plus I'm pretty sure the container is unable to set/sync date/time for the host machine.
EDIT: Oops I was wrong with above.
With the right caps it can:
But still, you dont need two time keepers.
