FTL will not update to V4.0
v4-0
#1
after running the up’ command FTL doesn’t update. It shows at the bottom of the dashboard update available. Ran -up 3 times and still shows same. Also pihole is not filtering anything. How do i fix or roll back update?
[Replace this text with what you think should be happening]
This is running on a raspberry pi zero w with the small display, as shown on Adafruit’s website.
Update to v4.0 failing curl: (22) The requested URL returned error: 404 Not Found
#2
What is the result of running the following command on the command line
pihole -v
#3
I got this result:
 [✓] Detected x86_64 architecture
  [i] Downloading and Installing FTL...curl: (22) The requested URL returned error: 404 Not Found
  Error: URL not found
  [✗] FTL Engine not installed
and
pihole@pihole:~$ pihole -v
  Pi-hole version is v4.0 (Latest: v4.0)
  AdminLTE version is v4.0 (Latest: v4.0)
  FTL version is v3.0 (Latest: v4.0)
pihole@pihole:~$
I couldnt update FTL
#4
Let’s make a change to your local name server to bypass Pi-Hole and try to get to the requested URL. The change is made once and will be overwritten on restart.
sudo nano /etc/resolv.conf and change 127.0.0.1 to 1.1.1.1 (using Cloudflare DNS instead of the Pi-Hole)
save this change and then run
pihole -up
Upgrade to Pi-Hole v4.0 failed
#5
I get the same as the other user.
pi@pi-hole:~ $ pihole -v
#6
I followed your instruction and now its current. I get
FTL version is v4.0 (Latest: v4.0)
:slight_smile: Thanks and have a great day! I’ll pass back this way the next time I need help. :slight_smile:
Now I shall see what ads it can slay! :smiley:
#7
got this again
#8
And again ;(
[i] FTL Checks...
I did as u said but it dont work for me ;(
 Current Pi-hole version is v4.0
  Current AdminLTE version is v4.0
  Current FTL version is v3.0
pihole@pihole:~$
Iam using this OS:
pihole@pihole:~$ cat /etc/os-release
NAME="Ubuntu"
VERSION="16.04.5 LTS (Xenial Xerus)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 16.04.5 LTS"
VERSION_ID="16.04"
HOME_URL="http://www.ubuntu.com/"
SUPPORT_URL="http://help.ubuntu.com/"
BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/"
VERSION_CODENAME=xenial
UBUNTU_CODENAME=xenial
pihole@pihole:~$
#9
I got it to work when I used this command:
pihole checkout master
Then it update fine :slight_smile:
[sudo] lösenord för pihole:
pihole@pihole:~$
#10
I’m getting the same thing. Made the change to resolve.conf, saved, but no joy with the pi-hole -up. I get an error as per the following:
  [i] Checking for updates...
  [i] Pi-hole Core:     up to date
  [i] FTL:              up to date
  [i] Web Interface:    update available
  [i] Pi-hole Web Admin files out of date
  [✓] Check for existing repository in /var/www/html/admin
  [i] Update repo in /var/www/html/admin...
  Error: Could not update local repository. Contact support.
This repeats if I do another pihole -up
My versions of software on a pi are:
  AdminLTE version is v3.3 (Latest: v4.0)
#11
@dmshimself
Please try the following commands
  1. sudo rm /var/www/html/admin
  2. sudo git clone https://github.com/pi-hole/AdminLTE.git /var/www/html/admin
  3. pihole -r and select repair
It is likely that through the install of a theme or mod to your web interface it has broken the upstream branch those command in that order should fix this
Can't update pihole
#12
That worked perfectly. The admin area was a directory so I changed the rm to an mv to somewhere and everything went through fine. Many thanks for the assist.
#13
