ich habe heute eine frische Installation von PiHole gemacht und bekomme leider FTL nicht als Onlien angezeigt.
Mein Token ist: t1qm7ouvnt
FTL läuft unter root:
root@localhost:~# sudo lsof -i :53
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
pihole-FT 17100 pihole 4u IPv4 218451 0t0 UDP *:domain
pihole-FT 17100 pihole 5u IPv4 218452 0t0 TCP *:domain (LISTEN)
pihole-FT 17100 pihole 6u IPv6 218453 0t0 UDP *:domain
pihole-FT 17100 pihole 7u IPv6 218454 0t0 TCP *:domain (LISTEN)
dnsmasq
root@localhost:~# /etc/init.d/dnsmasq status
[ ok ] Checking DNS forwarder and DHCP server: dnsmasq[....] (not running).
/var/log/pihole-FTL.log
[2019-09-12 13:57:13.570 16891] ########## FTL started! ##########
[2019-09-12 13:57:13.570 16891] FTL branch: master
[2019-09-12 13:57:13.570 16891] FTL version: v4.3.1
[2019-09-12 13:57:13.570 16891] FTL commit: b60d63f
[2019-09-12 13:57:13.570 16891] FTL date: 2019-05-25 21:37:26 +0200
[2019-09-12 13:57:13.570 16891] FTL user: pihole
[2019-09-12 13:57:13.570 16891] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-09-12 13:57:13.570 16891] SOCKET_LISTENING: only local
[2019-09-12 13:57:13.570 16891] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2019-09-12 13:57:13.570 16891] MAXDBDAYS: max age for stored queries is 365 days
[2019-09-12 13:57:13.570 16891] RESOLVE_IPV6: Resolve IPv6 addresses
[2019-09-12 13:57:13.570 16891] RESOLVE_IPV4: Resolve IPv4 addresses
[2019-09-12 13:57:13.570 16891] DBINTERVAL: saving to DB file every minute
[2019-09-12 13:57:13.570 16891] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-09-12 13:57:13.571 16891] MAXLOGAGE: Importing up to 24.0 hours of log data
[2019-09-12 13:57:13.571 16891] PRIVACYLEVEL: Set to 0
[2019-09-12 13:57:13.571 16891] IGNORE_LOCALHOST: Show queries from localhost
[2019-09-12 13:57:13.571 16891] BLOCKINGMODE: Null IPs for blocked domains
[2019-09-12 13:57:13.571 16891] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-09-12 13:57:13.571 16891] DBIMPORT: Importing history from database
[2019-09-12 13:57:13.571 16891] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-09-12 13:57:13.571 16891] PORTFILE: Using /var/run/pihole-FTL.port
[2019-09-12 13:57:13.571 16891] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-09-12 13:57:13.571 16891] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-09-12 13:57:13.571 16891] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-09-12 13:57:13.571 16891] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-09-12 13:57:13.571 16891] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-09-12 13:57:13.571 16891] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-09-12 13:57:13.572 16891] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-09-12 13:57:13.572 16891] MACVENDORDB: Using /etc/pihole/macvendor.db
[2019-09-12 13:57:13.572 16891] PARSE_ARP_CACHE: Active
[2019-09-12 13:57:13.572 16891] Finished config file parsing
[2019-09-12 13:57:13.574 16891] Database version is 3
[2019-09-12 13:57:13.574 16891] Database successfully initialized
[2019-09-12 13:57:13.575 16891] New forward server: 8.8.4.4 (0/512)
[2019-09-12 13:57:13.578 16891] New forward server: 8.8.8.8 (1/512)
[2019-09-12 13:57:13.581 16891] New forward server: 192.168.178.1 (2/512)
[2019-09-12 13:57:13.587 16891] Resizing "/FTL-strings" from 4096 to 8192
[2019-09-12 13:57:13.594 16891] Imported 3503 queries from the long-term database
[2019-09-12 13:57:13.595 16891] -> Total DNS queries: 3503
[2019-09-12 13:57:13.595 16891] -> Cached DNS queries: 2085
[2019-09-12 13:57:13.595 16891] -> Forwarded DNS queries: 357
[2019-09-12 13:57:13.595 16891] -> Exactly blocked DNS queries: 45
[2019-09-12 13:57:13.595 16891] -> Unknown DNS queries: 1016
[2019-09-12 13:57:13.595 16891] -> Unique domains: 228
[2019-09-12 13:57:13.595 16891] -> Unique clients: 6
[2019-09-12 13:57:13.595 16891] -> Known forward destinations: 3
[2019-09-12 13:57:13.595 16891] Successfully accessed setupVars.conf
[2019-09-12 13:57:13.595 16891] *************************************************************************
[2019-09-12 13:57:13.595 16891] * WARNING: Required Linux capability CAP_NET_ADMIN not available *
[2019-09-12 13:57:13.595 16891] * WARNING: Required Linux capability CAP_NET_RAW not available *
[2019-09-12 13:57:13.596 16891] *************************************************************************
[2019-09-12 13:57:13.596 16891] * WARNING: Required Linux capability CAP_NET_BIND_SERVICE not available *
[2019-09-12 13:57:59.153 17098] Using log file /var/log/pihole-FTL.log
Sind die Warnings hier das Problem?
[2019-09-12 13:58:00.009 17100] SQLite3 message: statement aborts at 22: [UPDATE network SET lastQuery = MAX(lastQuery, 1568287710) WHERE id = 3;] attempt to write a readonly database (8)
[2019-09-12 13:58:00.009 17100] dbquery(UPDATE network SET lastQuery = MAX(lastQuery, 1568287710) WHERE id = 3;) - SQL error (8): attempt to write a readonly database
[2019-09-12 13:58:00.010 17100] check_database(8): Disabling database connection due to error
