always the same problem : FTL offine
Thanks for help
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2019-01-18:16:30:13 debug log has been initialized.
[i] Core: v4.1.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.1.1-0-g8d85d46
[i] Web: v4.1.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.1.1-0-gde7aa5a
[✓] FTL: v4.1.2
[i] 1.4.45
[i] 7.0.33
[✓] Debian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✓] armv7l
192.168.31.40/24 matches the IP found in /etc/pihole/setupVars.conf
fe80::d263:b4ff:fe00:d846 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.31.1
* Pinging 192.168.31.1...
[✓] Gateway responded.
[127.0.0.1:53] is in use by pihole-FTL
[[::1]:53] is in use by pihole-FTL
*:22 sshd (IPv4)
*:22 sshd (IPv6)
[*:80] is in use by lighttpd
[✓] 612100.cn is via localhost (127.0.0.1)
[✗] Failed to resolve 612100.cn via Pi-hole (192.168.31.40)
[✓] doubleclick.com is 216.58.208.238 via a remote, public DNS server (8.8.8.8)
[✓] lighttpd daemon is active
BLOCKING_ENABLED=true
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.31.40/24
IPV6_ADDRESS=
PIHOLE_DNS_1=9.9.9.9
PIHOLE_DNS_2=149.112.112.112
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
[✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 2635634 Jan 18 08:48 /etc/pihole/gravity.list
0.0.0.0
0.r.msn.com
0.start.bz
000.0x1f4b0.com
zzz.clickbank.net
zzzezeroe.fr
zzzpooeaz-france.com
zzzrtrcm2.com
-rw-r--r-- 1 root root 381 Jan 18 08:16 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 44 Jan 18 08:48 /etc/pihole/local.list
192.168.31.40 Pi-Hole
192.168.31.40 pi.hole
-rw-r--r-- 1 root root 234 Jan 18 08:48 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 1421 Jan 18 08:48 /etc/dnsmasq.d/01-pihole.conf
user=pihole
group=pihole
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=9.9.9.9
server=149.112.112.112
interface=eth0
-rw-r--r-- 1 root root 3102 Jan 18 08:48 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1704 Jan 18 08:48 /etc/cron.d/pihole
52 3 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
27 18 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 1017 Jan 18 08:53 /var/log/lighttpd/error.log
2019-01-18 07:31:25: (log.c.217) server started
2019-01-18 07:32:49: (server.c.1828) server stopped by UID = 0 PID = 1
2019-01-18 07:32:49: (log.c.217) server started
2019-01-18 07:47:50: (server.c.1828) server stopped by UID = 0 PID = 1
2019-01-18 07:47:51: (log.c.217) server started
2019-01-18 07:48:48: (server.c.1828) server stopped by UID = 0 PID = 1
2019-01-18 07:48:59: (log.c.217) server started
2019-01-18 08:00:39: (server.c.1828) server stopped by UID = 0 PID = 1
2019-01-18 08:00:41: (log.c.217) server started
2019-01-18 08:17:31: (server.c.1828) server stopped by UID = 0 PID = 1
2019-01-18 08:17:32: (log.c.217) server started
2019-01-18 08:48:06: (server.c.1828) server stopped by UID = 0 PID = 1
2019-01-18 08:48:06: (log.c.217) server started
2019-01-18 08:49:37: (server.c.1828) server stopped by UID = 0 PID = 1
2019-01-18 08:49:51: (log.c.217) server started
2019-01-18 08:53:13: (server.c.1828) server stopped by UID = 0 PID = 1
2019-01-18 08:53:24: (log.c.217) server started
-rw-r--r-- 1 pihole pihole 35118 Jan 18 08:53 /var/log/pihole-FTL.log
[2019-01-18 07:32:55.209] Using log file /var/log/pihole-FTL.log
[2019-01-18 07:32:55.210] ########## FTL started! ##########
[2019-01-18 07:32:55.210] FTL branch: master
[2019-01-18 07:32:55.210] FTL version: v4.1.2
[2019-01-18 07:32:55.211] FTL commit: b06eedf
[2019-01-18 07:32:55.211] FTL date: 2018-12-21 14:43:34 -0600
[2019-01-18 07:32:55.211] FTL user: pihole
[2019-01-18 07:32:55.211] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-01-18 07:32:55.211] SOCKET_LISTENING: only local
[2019-01-18 07:32:55.211] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2019-01-18 07:32:55.212] MAXDBDAYS: max age for stored queries is 365 days
[2019-01-18 07:32:55.212] RESOLVE_IPV6: Resolve IPv6 addresses
[2019-01-18 07:32:55.213] RESOLVE_IPV4: Resolve IPv4 addresses
[2019-01-18 07:32:55.213] DBINTERVAL: saving to DB file every minute
[2019-01-18 07:32:55.213] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-01-18 07:32:55.213] MAXLOGAGE: Importing up to 24.0 hours of log data
[2019-01-18 07:32:55.213] PRIVACYLEVEL: Set to 0
[2019-01-18 07:32:55.214] IGNORE_LOCALHOST: Show queries from localhost
[2019-01-18 07:32:55.214] BLOCKINGMODE: Null IPs for blocked domains
[2019-01-18 07:32:55.216] REGEX_DEBUGMODE: Inactive
[2019-01-18 07:32:55.216] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-01-18 07:32:55.216] DBIMPORT: Importing history from database
[2019-01-18 07:32:55.216] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-01-18 07:32:55.216] PORTFILE: Using /var/run/pihole-FTL.port
[2019-01-18 07:32:55.216] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-01-18 07:32:55.217] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-01-18 07:32:55.217] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-01-18 07:32:55.218] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-01-18 07:32:55.218] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-01-18 07:32:55.218] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-01-18 07:32:55.218] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-01-18 07:32:55.218] Finished config file parsing
[2019-01-18 07:32:55.218] INFO: No whitelist file found
[2019-01-18 07:32:55.219] Compiled 0 Regex filters and 0 whitelisted domains in 0.2 msec (0 errors)
[2019-01-18 07:32:55.221] db_init() - Cannot open database (14): unable to open database file
[2019-01-18 08:53:23.747] MAXDBDAYS: max age for stored queries is 365 days
[2019-01-18 08:53:23.749] RESOLVE_IPV6: Resolve IPv6 addresses
[2019-01-18 08:53:23.749] RESOLVE_IPV4: Resolve IPv4 addresses
[2019-01-18 08:53:23.749] DBINTERVAL: saving to DB file every minute
[2019-01-18 08:53:23.749] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-01-18 08:53:23.749] MAXLOGAGE: Importing up to 24.0 hours of log data
[2019-01-18 08:53:23.749] PRIVACYLEVEL: Set to 0
[2019-01-18 08:53:23.749] IGNORE_LOCALHOST: Show queries from localhost
[2019-01-18 08:53:23.751] BLOCKINGMODE: Null IPs for blocked domains
[2019-01-18 08:53:23.752] REGEX_DEBUGMODE: Inactive
[2019-01-18 08:53:23.752] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-01-18 08:53:23.752] DBIMPORT: Importing history from database
[2019-01-18 08:53:23.752] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-01-18 08:53:23.752] PORTFILE: Using /var/run/pihole-FTL.port
[2019-01-18 08:53:23.752] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-01-18 08:53:23.752] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-01-18 08:53:23.754] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-01-18 08:53:23.754] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-01-18 08:53:23.754] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-01-18 08:53:23.754] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-01-18 08:53:23.754] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-01-18 08:53:23.754] Finished config file parsing
[2019-01-18 08:53:23.756] INFO: No whitelist file found
[2019-01-18 08:53:23.756] Compiled 0 Regex filters and 0 whitelisted domains in 1.4 msec (0 errors)
[2019-01-18 08:53:23.773] Database successfully initialized
[2019-01-18 08:53:23.775] Imported 0 queries from the long-term database
[2019-01-18 08:53:23.775] -> Total DNS queries: 0
[2019-01-18 08:53:23.775] -> Cached DNS queries: 0
[2019-01-18 08:53:23.776] -> Forwarded DNS queries: 0
[2019-01-18 08:53:23.776] -> Exactly blocked DNS queries: 0
[2019-01-18 08:53:23.776] -> Unknown DNS queries: 0
[2019-01-18 08:53:23.776] -> Unique domains: 0
[2019-01-18 08:53:23.776] -> Unique clients: 0
[2019-01-18 08:53:23.776] -> Known forward destinations: 0
[2019-01-18 08:53:23.776] Successfully accessed setupVars.conf
*** [ DIAGNOSING ]: Locale
LANG=
-rw-r--r-- 1 pihole pihole 0 Jan 18 08:53 /var/log/pihole.log
-----head of pihole.log------
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
* Using openssl for transmission.
[✓] Your debug token is: 4g9qxqw58b
* Provide the token above to the Pi-hole team for assistance at
* https://discourse.pi-hole.net
* Your log will self-destruct on our server after 48 hours.
* A local copy of the debug log can be found at: /var/log/pihole_debug-sanitized.log
