FTL not able to update to V 5.0, recurring error 404 github URL not found when attempting to update.
Details about my system:
Debug token: irdbrki8wt
Running on home network, static IP's setup on each device, worked well up until I attempted the update to 5.0.
Last I checked I was running Buster version of raspbian, and I've already updated raspbian as well.
I've attempted a few different changes, such as taking advice from this thread.
I've also attempted adding github to the pihole whitelist, to no avail.
I've also attempted changing the DNS in this file to an external one, can't find the thread I got the advice from though, but it seemed to be a fairly common direction for a fix.
/etc/resolv.conf
I'm not sure why, but through all these changes I keep getting the same error:
[i] Downloading and Installing FTL...curl: (3) [globbing] bad range in column 70
Error: URL https://github.com/pi-hole/ftl/releases/latest/download/pihole-FTL [i] [✓] Detected ARM architecture not found
[✗] FTL Engine not installed
Any help would be appreciated... I've been scouring the forums for a day or two now to try and fix this but to no avail.
I attempted the fix in this thread, though it seems to have not worked, in fact it throws a very similar error barring the '404 URL not found' and specifying the URL.
Not quite progress, but I appreciate you looking into git for resolutions. I hadn't even thought of that to be honest.
pi@raspberrypi:~ $ pihole -v
Pi-hole version is v5.0 (Latest: v5.0)
AdminLTE version is v5.0 (Latest: v5.0)
FTL version is v4.3.1 (Latest: v5.0)
pi@raspberrypi:~ $ pihole -up
[i] Checking for updates...
[i] Pi-hole Core: up to date
[i] Web Interface: up to date
[i] FTL: update available
[i] FTL out of date, it will be updated by the installer.
[✓] Root user check
[i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u7
[i] Performing unattended setup, no whiptail dialogs will be displayed
[✓] Disk space check
[✓] Checking for dhcpcd5
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
[i] SELinux not detected
[i] Performing reconfiguration, skipping download of local repos
[✓] Resetting repository within /etc/.pihole...
[✓] Resetting repository within /var/www/html/admin...
[i] Main Dependency checks...
[✓] Checking for cron
[✓] Checking for curl
[✓] Checking for dnsutils
[✓] Checking for iputils-ping
[✓] Checking for lsof
[✓] Checking for netcat
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[✓] Checking for idn2
[✓] Checking for sqlite3
[✓] Checking for libcap2-bin
[✓] Checking for lighttpd
[✓] Checking for php7.0-common
[✓] Checking for php7.0-cgi
[✓] Checking for php7.0-sqlite3
[✓] Checking for php7.0-xml
[✓] Checking for php-intl
[✓] Enabling lighttpd service to start on reboot...
[i] FTL Checks...
[✓] Detected ARM architecture [i] Checking for existing FTL binary...
Error: URL https://github.com/pi-hole/ftl/releases/latest/download/pihole-FTL [✓] Detected ARM architecture not found
Thanks everyone for the support, also I don't think it'll matter much but my network topology is going to be changing in about a week or so due to the fact that I'll be moving!
pi@raspberrypi:/etc/.pihole $ pihole -v
FTL version is v5.0 (Latest: v5.0)
Thanks for the help! This has been bugging me for a while now and I feel like I'm not crazy anymore 'cause I've trying to fix this for weeks now.
