- Pi-hole v5.1.2
- Web Interface v5.1.1
- FTL · Update available!
The issue I am facing:
root@PogoPiHole:~# pihole -r
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] Existing PHP installation detected : PHP version 7.3.19-1~deb10u1
[i] Reconfigure option selected
[✓] Disk space check
[✓] Checking for dhcpcd5
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
[✓] Checking for dnsutils
[✓] Supported OS detected
[i] SELinux not detected
[i] Using interface: eth0
[i] Using upstream DNS: OpenDNS (ECS) (208.67.222.222, 208.67.220.220)
[i] Static IP already configured
[i] Found IPv6 GUA address, using it for blocking IPv6 ads
[i] IPv4 address: 192.168.1.87/24
[i] IPv6 address: 2002:d5db:9c3b:0:225:31ff:fe02:825b
[i] Web Interface On
[i] Web Server On
[i] Logging On.
[i] Privacy level 0 [i] Performing reconfiguration, skipping download of local repos
[✓] Resetting repository within /etc/.pihole...
[✓] Resetting repository within /var/www/html/admin...
[i] Main Dependency checks...
[✓] Checking for cron
[✓] Checking for curl
[✓] Checking for iputils-ping
[✓] Checking for lsof
[✓] Checking for netcat
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[✓] Checking for idn2
[✓] Checking for sqlite3
[✓] Checking for libcap2-bin
[✓] Checking for lighttpd
[✓] Checking for php7.3-common
[✓] Checking for php7.3-cgi
[✓] Checking for php7.3-sqlite3
[✓] Checking for php7.3-xml
[✓] Checking for php7.3-intl
[✓] Enabling lighttpd service to start on reboot...
[i] FTL Checks...
[✓] Detected ARM architecture
/etc/.pihole/automated install/basic-install.sh: line 2529: /usr/bin/pihole-FTL: No such file or directory
pihole -r
[i] FTL Checks...
[✓] Downloading and Installing FTL
[✓] Installing scripts from /etc/.pihole
Details about my system:
armv6l GNU/Linux running Debian Buster
Checked hostname and host, multiple time apt-get update + apt-upgrade executed, pihole -r started, rebooted multiple times...
PiHole is currently not operational on my Pogoplug B03 (Classic)
