FTL Should show as running on the WebUI - but it don't.
SSH Input: sudo pihole-FTL
SSH Output: Notice: Found no readable FTL config fileFATAL: Opening of FTL log (/var/log/pihole-FTL.log) failed!
Make sure it exists and is writeable by user pi
hprrbzy0v1
Note: When I run pihole -D it shows "[✓] pihole-FTL daemon is active" // so maybe it's nothing.
May or May Not be related... but my dashboard tables no longer load either. Post updating.
