pihole-FTL isn't using much memory at all, 1.7MB out of 225.5MB available in the Shared Memory location.
You do have some errors that happen when there is a problem with the system time:
-rw-r--r-- 1 pihole pihole 9100 May 11 07:35 /var/log/pihole-FTL.log
[2021-05-11 00:03:43.618 17924M] Resizing "FTL-dns-cache" from 57344 to (3840 * 16) == 61440 (/dev/shm: 1.7MB used, 225.5MB total, FTL uses 1.7MB)
[2021-05-11 00:12:34.826 17924M] FATAL: Trying to access query ID -1, but maximum is 12288
[2021-05-11 00:12:34.835 17924M] found in FTL_query_in_progress() (/root/project/src/dnsmasq_interface.c:2181)
[2021-05-11 00:12:34.836 17924M] Failed to unlock SHM lock: Operation not permitted
[2021-05-11 00:49:29.472 17924M] FATAL: Trying to access query ID -1, but maximum is 12288
[2021-05-11 00:49:29.480 17924M] found in FTL_query_in_progress() (/root/project/src/dnsmasq_interface.c:2181)
[2021-05-11 00:49:29.487 17924M] Failed to unlock SHM lock: Operation not permitted
[2021-05-11 00:49:29.515 17924M] FATAL: Trying to access query ID -1, but maximum is 12288
[2021-05-11 00:49:29.516 17924M] found in FTL_query_in_progress() (/root/project/src/dnsmasq_interface.c:2181)
[2021-05-11 00:49:29.516 17924M] Failed to unlock SHM lock: Operation not permitted
[2021-05-11 00:59:01.157 17924/T17928] Notice: Database size is 784.02 MB, deleted 768 rows
The Pi Zero Ws aren't doing anything else. They're both dedicated to running pihole only. They have unattended-upgrades tweaked a bit, but aren't a huge deviation from a standard install.
That's interesting, I looked right past those timestamps. This is around the time unattended-upgrades was running. Any chance it was updating and killed pihole-FTL for more memory?
We generally advise against unattended upgrades of Pi-hole.
Could you share the config items you use to achieve that?
In the meantime, it should be easy enough to disable that and monitor your system whether that would fix your issue.
There should be some lines above those log messages that show the memory usage at the time of OOM-killer invocation, preceeded by an indication which process invoked it when running short on memory (something like <process> invoked OOM-killer).
Your debug log shows at least cloudflared to be running as well:
127.0.0.1:33419 cloudflare (IPv4)
127.0.0.1:5053 cloudflare (IPv4)
It doesn't seem that you are using this as Pi-hole's upstream?
In addition (and probably unrelated), you are using .local as your local domain name:
* Received 320 bytes from wlan0:192.168.0.1
Offered IP address: 192.168.0.4
Server IP address: 192.168.0.1
DHCP options:
Message type: DHCPOFFER (2)
server-identifier: 192.168.0.1
domain-name: "local"
dns-server: 192.168.0.3
dns-server: 192.168.0.4
router: 192.168.0.1
Note that .local is the default domain for the mDNS protocol - it should not be used with DNS.
Consider configuring your router for a different local domain name.
"unattended-upgrades" is the standard debian/ubuntu/raspbian package that handles automatic security updates -- nothing to do with pihole. I can try disabling it for the next week though.
I had issues with cloudflared DOH and stopped using it, but forgot to remove it. Good eye. I nuked it from both, thanks.
I found the OOM-killer section you're referencing and attached that portion of the log.
Thanks for the analysis, apt-get was my guess since unattended-upgrades was running around this time.
This is the secondary pihole and total queries on dashboard shows 7,678. Primary shows 26,062.
Currently top shows:
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
755 pihole 10 -10 90236 20016 4524 S 0.0 4.5 10:44.46 pihole-FTL
Considering the virtual memory you noted used by cloudflared, I'm curious if that was the issue all along. I've uninstalled that from both piholes, and disabled unattended-upgrades on one.
I don't really think so. Did I got you right that the memory need increases slowly until you hit the very point where it is just used up? In this case, we'll have to run some memory-leak checks on your system.
I wrote some documentation about it that should make it not especially easy, but doable:
DNS service is not functioning, so I am doing something wrong. Should the standard pihole-FTL log still be getting populated? It's not.
While this may be useful to see if there's an actual memory leak in FTL, I'm starting to think just reloading the pi and copying my handful of config changes (static DNS, additional lists) may be more productive.
Helping to debug is completely voluntary, of course. If it is too troublesome for you, you don't have to do it. Sorry for the inconvenience caused by this either way!
I gave this a try with the same result. Valgrind seems to just hang. I would expect the program to keep running and for it to print more debugging information. I attached a log of what it does.
I found this Stackoverflow link that describes how a newer version of Valgrind resolves the issue, but confirms that Raspbian Buster is not adequately maintaining Valgrind.
Valgrind is a useful C/C++ Development tool and probably deserves to be maintained. This is making me wish I tried Ubuntu 20.04 32-bit ARM when it came out.
Okay, too bad that it doesn't work as expected. Maybe it is time to try Ubuntu out now? I do have a testing system with Ubuntu 64bit (aarch64) on a Raspberry Pi 3 running here and it seems to be doing the job quite fine.
Roughly a month ago I reloaded my Macbook and I had previously disabled bonjour. The piholes were set to only display A and AAAA requests, but the Macbook with bonjour enabled was drowning them in reverse DNS lookups (PTR requests). The new piholes with fresh configurations shot up to over 150k each in a day. IMO it seems reasonable that >100k requests a day could be a bit much for a Zero.
Upon disabling bonjour on the Macbook, the number of queries per hour returned to a normal count.
I apologize for the wasted time, and I'm certain I am not the first to encounter this. I will not be filtering PTR requests again.
No need to apologize for anything. But yeah, that's not the first time something like this happens and why we are going to deprecate this option in the near future.
