The services for DNS and FTL should start and be stable
DNS and FTL after doing a pihole -up and restarting the pi. those services will not come back up and I can't get out to the internet
[Moderator removed your debug log and made it private]
jfb
3
These steps will temporarily change the Pi name server to a commercial DNS so you can run an update.
sudo nano /etc/resolv.conf
Change 127.0.0.1 to 1.1.1.1, save and exit
pihole -up
That worked, I got everything updated to version 4.0. Is this something that I should leave or change?
jfb
5
If it hasn't already changed back to 127.0.0.1, then change it back.
Is your Pi-Hole working properly now? Try uploading a debug log and post the token and we'll check it.
It is working correctly now without any issues, thank you for your help!
system
Closed
7
