Stealing an idea from myself, and from another thread,,,,,
So if the end-user is running the master branch, and they accidentally break something,,
running pihole checkout master
will potentially repair better than pihole -r
Additionally it's been pointed out that navigating to /var/www/html/admin
and running sudo git reset --hard
, will fix the webui (if that's the issue).
I recently had to redo my pihole, because i broke things so bad. (I can never stop tinkering). I wish I had thought to do the checkout command to redownload the repository.
This prompted me with an idea for pihole -r to have a third option to "fresh start reinstall".
This would:
- create a "teleport" and ask if the user wishes to retain the adlists, whitelist, and blacklist files.
- move all the pihole files to a temporary directory,
- re-download the repositories,
- apply a fresh lighttpd conf,
and if an error occurs during this process offer an option to either:
- revert the changes by moving things back from the temporary directory,
- or to remove the files from the temporary directory.
