Not without some advanced configuration. That's why we put that large warning in the file.
I've moved this to Community Help since that is where we put topics that are custom configured, per the template that was deleted when this post was created.
ok thank you.
so i'm in a big trouble if i can't have multiple web site easily...
i have replace the original lighttpd.conf file and i think the pihole is working
after a reboot, it's back to not working like before ![]()
Does
su -s /bin/sh -s "cat /etc/os-release" "pi"
Work if you use the password for pi? It may be a segmentation fault in another binary.
it's not working, segmentation error
Okay, then the problem is with the underlying operating system and not with Pi-hole itself.
Looks like you'll need to reinstall the OS if su or /bin/sh is broken.
Edlt: It's su that is broken. the /bin/sh was never even called.
so i've reinstall almost everything on my RPI and it's look like to work. now i have to figure out how to make it work with several websites.
thank you for your help
