Greetings all, I arrive here having looked at numerous guides and tried a few things already without success.
I run Pi-Hole on a Rasp PI and I also have a separate Rasp PI which has OpenVPN running on it, both locked down via firewalls to ensure only the OpenVPN is exposed to outside world.
VPN connection was working and giving access to internal LAN just fine until I enabled DHCP on the Pi-Hole (something I had to do due to Netgear router not supporting DNS on internal IP)
I am certain I need to bridge or forward the traffic between the eth0 and tun0 connections somehow, but as said every guide that I thought solved the issue, has failed to do so, also concede this is more an OpenVPN issue than Pi-hole, but hoping a bright mind has had this same issue here. Thanks in advance.
Connect to VPN from outside world, and remotely access CCTV on 192.168.0.141:9000
Unable to access any internal IP (including Pi-hole) from the VPN tunnel. I cannot ping any LAN side host from the Tun0 connection.
I can however ping from eth0 (on the Lan side) fine.
LAN settings
Pi-hole IP 192.168.0.53
OpenVPN 192.168.0.54
LAN IP range 192.168.0.0/24
Gateway 192.168.0.1
VPN Tun range 10.8.0.0/24
