Hat jemand eine Idee, warum das Update auf 4.1 nicht lΓ€uft!?
pi@raspberrypi:~ $ sudo pihole -up
[i] Checking for updates...
fatal: unable to access 'https://github.com/pi-hole/pi-hole.git/': Could not resolve host: github.com
[i] Pi-hole Core: up to date
fatal: unable to access 'https://github.com/pi-hole/AdminLTE.git/': Could not resolve host: github.com
[i] Web Interface: up to date
[i] FTL: update available
[i] FTL out of date, it will be updated by the installer.
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u1
[i] Performing unattended setup, no whiptail dialogs will be displayed
[β] Disk space check
[β] Update local cache of available packages
[β] Checking apt-get for upgraded packages... up to date!
[β] Checking for apt-utils
[β] Checking for dialog
[β] Checking for debconf
[β] Checking for dhcpcd5
[β] Checking for git
[β] Checking for iproute2
[β] Checking for whiptail
[i] Performing reconfiguration, skipping download of local repos
[β] Resetting repository within /etc/.pihole...
[β] Resetting repository within /var/www/html/admin...
[i] Main Dependency checks...
[β] Checking for bc
[β] Checking for cron
[β] Checking for curl
[β] Checking for dnsutils
[β] Checking for iputils-ping
[β] Checking for lsof
[β] Checking for netcat
[β] Checking for psmisc
[β] Checking for sudo
[β] Checking for unzip
[β] Checking for wget
[β] Checking for idn2
[β] Checking for sqlite3
[β] Checking for libcap2-bin
[β] Checking for dns-root-data
[β] Checking for resolvconf
[β] Checking for lighttpd
[β] Checking for php7.0-common
[β] Checking for php7.0-cgi
[β] Checking for php7.0-sqlite3
[β] Enabling lighttpd service to start on reboot
[β] Installing scripts from /etc/.pihole
[β] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
[i] Installing blocking page...
[β] Creating directory for blocking page, and copying files
[β] Backing up index.lighttpd.html
[β] Installing sudoer file
[β] Installing latest Cron script
[β] Installing latest logrotate script
[i] FTL Checks...
[β] Detected ARM-hf architecture (armv7+)
[β] Downloading and Installing FTL
Error: Unable to get latest release location from GitHub
[β] FTL Engine not installed
[β] man pages installed and database updated
[i] Systemd-resolved is not enabled
[β] Starting lighttpd service
[i] Restarting services...
[i] Starting pihole-FTL service...^C
pi@raspberrypi:~ $ [i] Installing blocking page...
-bash: [i]: Kommando nicht gefunden.
pi@raspberrypi:~ $ [β] Creating directory for blocking page, and copying files
-bash: [β]: Kommando nicht gefunden.
pi@raspberrypi:~ $ [β] Backing up index.lighttpd.html
pi@raspberrypi:~ $ No default index.lighttpd.html file found... not backing up
-bash: No: Kommando nicht gefunden.
pi@raspberrypi:~ $
pi@raspberrypi:~ $ [β] Installing sudoer file
pi@raspberrypi:~ $
pi@raspberrypi:~ $ [β] Installing latest Cron script
pi@raspberrypi:~ $
pi@raspberrypi:~ $ [β] Installing latest logrotate script
pi@raspberrypi:~ $
pi@raspberrypi:~ $ [i] FTL Checks...
pi@raspberrypi:~ $ [β] Detected ARM-hf architecture (armv7+)
-bash: Syntaxfehler beim unerwarteten Wort `('
pi@raspberrypi:~ $ [i] Checking for existing FTL binary...
pi@raspberrypi:~ $ [β] Downloading and Installing FTL
pi@raspberrypi:~ $ Error: Unable to get latest release location from GitHub
-bash: Error:: Kommando nicht gefunden.
pi@raspberrypi:~ $ [β] FTL Engine not installed
pi@raspberrypi:~ $ sudo shutdown -r 0
Shutdown scheduled for Sat 2018-12-29 10:02:54 CET, use 'shutdown -c' to cancel.
pi@raspberrypi:~ $
login as: pi
pi@192.168.190.3's password:
Linux raspberrypi 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Dec 29 09:45:52 2018 from 192.168.190.70
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[β] Checking for bc
[i] FTL Checks...
[β] Starting pihole-FTL service
[β] Enabling pihole-FTL service to start on reboot
[β] Deleting existing list cache
[β] Pulling blocklist source list into range
[i] Target: raw.githubusercontent.com (hosts)
[β] Status: Connection Refused
[β] List download failed: no cached list available
[i] Target: mirror1.malwaredomains.com (justdomains)
[i] Target: sysctl.org (hosts)
[i] Target: zeustracker.abuse.ch (blocklist.php?download=domainblocklist)
[i] Target: s3.amazonaws.com (simple_tracking.txt)
[i] Target: s3.amazonaws.com (simple_ad.txt)
[i] Target: v.firebog.net (Easylist.txt)
[i] Target: v.firebog.net (Easyprivacy.txt)
[β] Consolidating blocklists
[β] Extracting domains from blocklists
[i] Number of domains being pulled in by gravity: 0
[β] Removing duplicate domains
[i] Number of unique domains trapped in the Event Horizon: 0
[i] Number of whitelisted domains: 2
[i] Number of blacklisted domains: 0
[i] Number of regex filters: 0
[β] Parsing domains into hosts format
[β] Cleaning up stray matter
[β] Force-reloading DNS service
[β] DNS service is running
[β] Pi-hole blocking is Enabled
[i] The install log is located at: /etc/pihole/install.log
Update Complete!
Current Pi-hole version is v4.0
Current AdminLTE version is v4.0
Current FTL version is v4.0
