Feeling kinda conflicted about this post.
This site helps people with pi but it pops up an annoying popup advert after a few seconds.
Wouldn’t be so bad if it was an advert at side or bottom of page but I find the popup quite annoying.
Anyway, I feel quite conflicted about asking if pihole can stop this popup, but it is a popup and pihole is created to stop popups among other things.
Does anyone know how to stop the popup with pihole?
Thank you.
Pi-hole doesn't know what a popup is.
Pi-hole is designed to block domains.
If an ad (or the javascript code used to generated the ad popup) is loaded from a blocked domain, Pi-hole will block it.
Popups are annoying, but seems that the popup in the screen shot is also an old article from the site. Either that or the screen capture missed the popup.
To be sure, there is other popups on the site that appeared while navigating through the articles on the site. Not not a great user experience experience, but also, as mentioned by rdwebdesign, there is little Pi-hole can do if the popup is served by the same site you are visiting, or another site that is not blocked.
I’d attribute this to bad script on the site that does no properly handle the user having already seen the popup.
For what it’s worth, a popup also appears on that site with UBlock Origin extension running in the web browser, which is pretty unusual. In this test, Pihole is not running.
