using nginx and follow the instruction for recursive DNS server setup only to fail at the end of the installation.
Complete opertional working unbound
-operating system: Rasiberry Pi
-hardware: Rasiberry Pi 4b
pi@raspberrypi:~ $ sudo apt install unbound
Reading package lists... Done
Building dependency tree
unbound
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 671 kB of archives.
After this operation, 3,637 kB of additional disk space will be used.
Get:1 http://mirrors.pidginhost.com/raspbian/raspbian buster/main armhf unbound armhf 1.9.0-2+deb10u2 [671 kB]
Fetched 671 kB in 3s (218 kB/s)
Selecting previously unselected package unbound.
(Reading database ... 159767 files and directories currently installed.)
Preparing to unpack .../unbound_1.9.0-2+deb10u2_armhf.deb ...
Unpacking unbound (1.9.0-2+deb10u2) ...
Setting up unbound (1.9.0-2+deb10u2) ...
Job for unbound.service failed because the control process exited with error code.
See "systemctl status unbound.service" and "journalctl -xe" for details.
invoke-rc.d: initscript unbound, action "restart" failed.
โ unbound.service - Unbound DNS server
Active: activating (auto-restart) (Result: exit-code) since Tue 2021-09-21 18:53:51 AEST; 26ms ago
Docs: man:unbound(8)
Process: 17491 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=1/FAILURE)
Process: 17500 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=1/FAILURE)
Process: 17503 ExecStart=/usr/sbin/unbound -d $DAEMON_OPTS (code=exited, status=1/FAILURE)
Main PID: 17503 (code=exited, status=1/FAILURE)
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for systemd (241-7~deb10u8+rpi1) ...
pi@raspberrypi:~ $
By default Unbound uses port 53, the same port is already being used by pihole-FTL.
You can change the port for Unbound in its configuration file, for example
It out to be a mess in the first place, so I started from scratch again and it now working properly, only this time my browser failed to do a proper backup of pi-hole settings, any chance I can get a copy of the log file that was up load to the git site which has the part of the pi-hole regex blocks.
Thank you for trying but most of the regex is truncated, is it possible just to upload the logfile to my account as a attachment or email it my gmail account.
I did create the backup, like many before, but the brave browser is giving me trouble in saving any download files and I keep forgetting the browser issue of not saving any files, they simple evaporate into nothing. General I do all backups or downloads in Firefox with no issue, all these issue was caused with impatiences on my behave, all over unbound issue to start with..
That is all I, as a user see anyway. I did find the backup file after all on the time machine, however the backup didn't restore correctly given all the setting are in tact, hence I have a feeling that the restore process had trouble with large regex filters and simply drop them as the small regex filter went through fine.
