so do i edit this .conf file? e.g. using nano?
Then "pihole -r"?
If so, how do i configure additional IP4 addresses?
For example, can i set "PIHOLE_DNS_3" to an IP4 address?
Can i add additional PIHOLE_DNS lines? e.g. "PIHOLE_DNS_5="
Thanks.
Then "pihole -r"?
Thanks.
sudo nano /etc/pihole/setupVars.conf will get you into the editor. Make the changes, save and exit.
Then sudo service pihole-FTL restart will restart FTL.
Yes. Change existing lines as needed, or add new lines, or both.
