lug-gh
August 10, 2018, 8:49pm
1
hi, when running pihole -up from version 3 to 4 it fails, without an error message i could interpret.
pihole -up
https://pastebin.com/HCecfNig
running pihole in lxc container (proxmox)
it updates and runs like charm
fails update
before update: dvdz4gb8wx
after update: 89w12qjlym
Have you in past made any changes such as themeing to your lighttpd install?
lug-gh
August 11, 2018, 1:22am
4
no, i didn't touch lighttpd, i only changed the dnsmasq ttl value.
jfb
August 11, 2018, 1:24am
5
There are a few quick things we can try. Your debug log shows you fully at V4, but none of the Pi-Hole services are shown as running.
pihole -r
and select repair option
reboot the pi
lug-gh
August 11, 2018, 1:25am
6
pihole -r
already done that
reboot the pi
i run lxc container in proxmox
because i have a snapshot i can try whatever u want
jfb
August 11, 2018, 1:26am
7
I should have noticed not on a Pi. My error.
lug-gh
August 11, 2018, 1:29am
8
debug token for pihole -r : hx7jf3nkmr
after repair i have to uninstall dhcpd, because it breaks networking on lxc containers..
debug token after reboot and failed upgrade: 6j1t0ogf62
edit: just tested, fresh install works, so there shouldn't be a compatibility problem.
jfb
August 11, 2018, 1:43am
10
Is your problem resolved?
lug-gh
August 11, 2018, 2:01am
11
No I meant a fresh install of pihole works on a new deployed lxc container.
Update still fails on my existing Installations.
jfb
August 11, 2018, 3:28am
12
I believe your best approach may be to continue with what worked for you, a fresh install on the other containers. That is likely to be a quicker solution than attempting to repair your existing installation.
If you go this route, use the teleport to export you current settings, which you can then transfer to the new installation.
system
Closed
September 1, 2018, 3:28am
13
