There is an encrypted domain name list for security reasons, how can I integrate this list? For example, google.com domain name in my list is encrypted with sha1 "baea954b95731c68ae6e45bd1e252eb4560cdc45" Do you have any solution for this issue?
I'm trying to write a custom control that will do the action I have specified, but I couldn't figure out how to integrate it into the source code, in which function to do this, can you help with this?
Presumably the sha1 checksums are produced from a source of domain names. Amend the process which produces the checksums to also produce and modify a text file list in hosts format, ie
# comments if needed
# eg last updated date and time
0.0.0.0 example.com
0.0.0.0 example.org
and make this available as a txt file at a URL. Add the URL to Pi-hole in the Adlists section.
but it's very nested. I would not change the code here - if you modify the file locally, you need to redo it after every update. I suggest that you run a separate script to decrypt the file, save it locally and add the local file to your adlist (e.g. file:///home/piuser/decrpyt.txt)
Just wondering:
What is the motivation to apply encryption to a list of domains?
It's seems counter-intuitive to render a perfectly human readable list illegible.
It's going to make things a lot harder, e.g. to identify issues and report them back to the list maintainer.
I can't decrypt sha1 because it's a one-way hack. I can't think of any other way to do this as the list is encrypted for data protection reasons. As you said the source code is nested and I couldn't figure out which function to do this in and I'm not very good at c-object language.
