Enabling Unbound-Control: get error
Currently trying to enable unbound-ctonrol. When I enter the command:
sudo -u unbound unbound-control-setup
end up with error message:
cannot create server.cnf: Permission denied
Try run it as root instead of the unbound user eg:
sudo unbound-control-setup
Worked for below:
FYI:
$ man unbound-control
SET UP
       The  setup  requires a self-signed certificate and private keys for
       both the server and client.  The script unbound-control-setup  gen‐
       erates  these  in  the default run directory, or with -d in another
       directory.
Where did you get that -u unbound from?
That’s what was listed on the Unbound documentation. However, I think the issue was with a custom AppArmor profile, that came installed with Unbound. Running as root did work however.
The real issue appeared to be I somehow removed the reference to remotecontrol.conf from the unbound.conf file, meaning I couldn’t use the remote-control feature.
More specific pls?
EDIT: Never mind, found it:
