I have recently migrated my Pi-hole install to a new Ubuntu 20.04 PVE LXC. In setting up the SSL certificates from CloudFlare via Certbot DNS, I discovered that the mod_openssl server module appeared to not be installed or enabled.
I have now installed lighttpd-mod-openssl from apt and added it to the server.modules but this can only be done in /etc/lighttpd/lighttpd.conf it seems (I did try in external.conf but that didn't work).
Thus after every update, I will need to re-add the server.module.
Is there another workaround, or could it be enabled as standard?
# FILE AUTOMATICALLY OVERWRITTEN BY PI-HOLE INSTALL/UPDATE PROCEDURE. #
# CHANGES SHOULD BE MADE IN A SEPARATE CONFIG FILE: #
# /etc/lighttpd/external.conf #
From the top of the file which will stop it
being overwritten on the next update
We are taking steps that prevent us from clobbering the default lighttpd config on newer installs - as it's just bad practice. But that also means you can swap out lighttpd config on an existing install and things should still work because we have migrated the relevant stuff for us into conf-available/15-pihole-admin.conf
