All queries that come in, are also visible at the Dashboard like normal queries via port 53
Queries via DoT/stunnel are blocked correctly, but not visible at the Dashboard. All other normal queries are visible.
For some time now i use successfully a pi-hole. All queries are shown at the dashboard. Since some days now, my phone is updated to Android 9. Since there is support for DoT build in, i have tried to setup a proxy with stunnel between pi-hole and the Android 9 phone. Basically it seems to work, but the queries are only visible in /var/log/pihole.log. DNS queries from the pi-hole machine (localhost) like ping www.google.com are visible at the dashboard.
Yes, i know, its not directly supported. My problem is, that i didn't understand why it seems to work and block ads and trackers successfully, but i didn't see the queries. So i should better ask: How or what for queries are displayed at the dashboard and what 's the difference between queries via port 53 and queries via a proxy from port 853 to 53? Both are queries from localhost for pi-hole, the difference is only that 853 is only available as TCP port and 53 as UDP/TCP. If i understand it, maybe i can change it at my side or maybe i could make a fork and pull request. But i don't know where to start.
Update:
I have tried to research a little bit and found only one thing so long:
If there is a entry like "query[A] blockads.fivefilters.org from 127.0.0.1" in /var/log/pihole.log, this query is missing from the dashboard and is also not recorded in pihole-FTL.db. But if the line is: "query[A] blockads.fivefilters.org from 10.8.0.2", it is available in Dashboard and pihole-FTL.db. So it seems that queries from 127.0.0.1 are filtered out. I don't know if there is some reason for this.
Update 2:
After googling around i found Avoid localhost request in stats? · Issue #496 · pi-hole/pi-hole · GitHub. Is this the reason not showing that requests?. If so, than i try to found a way to workaround this. Would be great, if someone could explain it to me, before i start to implement a workaround/patch.
Sorry I didn't answer your post. I had a lot to do with my Primitivenotes plugin for Roundcube. With the todays update to Pi-Hole 4.2 the problem doesn't exist anymore. Many thanks for the update and Pi-Hole project in general.
