Pihole has been running unattended for a week or so, I hadn't logged in at all. Just fired up the browser to see some statistics, and it is only blocking 142 domains. I have a lot of lists configured for blocking. I forced an update to all the lists, and I'm still at 142. I rebooted, still at 142.
What happened to the zillions of domains pihole used to block for me???
so we can help debug the issue.
Can you share the output of pihole -g
from the command line? You definitely have a lot of lists and I can see your blacklist is populated. The output from the command will help diagnose the issue further. It's not something we usually account for in the debug log.
I'm guessing the "no space left on device" has something to do with the problem, hahahaha. Is a 2GB sdcard not enough for pihole plus a lot of lists?
Thanks.
pi@pi-hole:~ $ pihole -g
[i] Target: raw.githubusercontent.com (hosts)
[i] Target: mirror1.malwaredomains.com (justdomains)
[i] Target: sysctl.org (hosts)
[✓] Status: No changes detected
[i] Target: zeustracker.abuse.ch (blocklist.php?download=domainblocklist)
[i] Target: s3.amazonaws.com (simple_tracking.txt)
[i] Target: s3.amazonaws.com (simple_ad.txt)
[i] Target: gist.github.com (36140c95bc105ee13cdc672baa940ab0#file-blacklist-txt)
[i] Target: gist.github.com (d136976b382029f7043883bd0f024f07#file-03-pihole-wildcard-conf)
[i] Target: raw.githubusercontent.com (pi_blocklist_porn_all.list)
[i] Target: hosts-file.net (grm.txt)
[i] Target: reddestdream.github.io (minimalhosts)
[i] Target: v.firebog.net (w3kbl.txt)
[i] Target: v.firebog.net (BillStearns.txt)
[i] Target: www.dshield.org (suspiciousdomains_Low.txt)
[i] Target: www.joewein.net (dom-bl-base.txt)
[i] Target: raw.githubusercontent.com (spammers.txt)
[i] Target: hostsfile.org (hosts.txt)
[i] Target: someonewhocares.org (hosts)
[i] Target: raw.githubusercontent.com (main-blacklist.txt)
[i] Target: winhelp2002.mvps.org (hosts.txt)
[i] Target: hostsfile.mine.nu (hosts0.txt)
[i] Target: v.firebog.net (Kowabit.txt)
[i] Target: adblock.mahakala.is (adblock.mahakala.is)
[i] Target: adaway.org (hosts.txt)
[i] Target: v.firebog.net (AdguardDNS.txt)
[i] Target: v.firebog.net (Easylist.txt)
[✗] Status: Not found
[✗] List download failed: no cached list available
[i] Target: v.firebog.net (Airelle-trc.txt)
[i] Target: v.firebog.net (Easyprivacy.txt)
[i] Target: v.firebog.net (Prigent-Ads.txt)
[i] Target: raw.githubusercontent.com (trackers.txt)
[i] Target: gist.githubusercontent.com (Canvas%2520Font%2520Fingerprinting%2520pages%2520%255B2017%2520Edition%255D)
[i] Target: gist.githubusercontent.com (WebRTC%2520tracking%2520list%2520%255B2017%2520Edition%255D.txt)
[i] Target: gist.githubusercontent.com (Audio%2520fingerprint%2520pages%2520%255B2017%2520Edition.exe)
[i] Target: gist.githubusercontent.com (Canvas%2520fingerprinting%2520pages%2520%255B2017%2520Edition%255D.exe)
[i] Target: v.firebog.net (SamsungSmart.txt)
[i] Target: v.firebog.net (Airelle-hrsk.txt)
[i] Target: s3.amazonaws.com (simple_malvertising.txt)
[i] Target: hosts-file.net (exp.txt)
[i] Target: hosts-file.net (emd.txt)
[i] Target: hosts-file.net (psh.txt)
[i] Target: mirror.cedia.org.ec (immortal_domains.txt)
[i] Target: www.malwaredomainlist.com (hosts.txt)
[i] Target: bitbucket.org (Mandiant_APT1_Report_Appendix_D.txt)
[i] Target: v.firebog.net (Prigent-Malware.txt)
[i] Target: v.firebog.net (Prigent-Phishing.txt)
[i] Target: raw.githubusercontent.com (malicious-sites.txt)
[i] Target: ransomwaretracker.abuse.ch (RW_DOMBL.txt)
[i] Target: v.firebog.net (Shalla-mal.txt)
[i] Target: github.com (pi_blocklist_porn_all.list)
[i] Target: raw.githubusercontent.com (pi_blocklist_porn_top1m.list)
[i] Consolidating blocklists...tr: write error: No space left on device
tr: write error
/opt/pihole/gravity.sh: line 387: echo: write error: No space left on device
tr: write error
tr: write error
tr: write error
tr: write error
[✓] Consolidating blocklists
[i] Extracting domains from blocklists...sed: couldn't write 16 items to stdout: No space left on device
[✓] Extracting domains from blocklists
[i] Number of domains being pulled in by gravity: 0
[✓] Removing duplicate domains
[i] Number of unique domains trapped in the Event Horizon: 0
/opt/pihole/gravity.sh: line 427: cannot create temp file for here-document: No space left on device
[i] Number of blocklist source domains being added to the whitelist: 0
[i] Number of whitelisted domains: 88
[i] Number of blacklisted domains: 142
[i] Number of wildcard blocked domains: 2
[i] Parsing domains into hosts format...awk: write failure (No space left on device)
awk: close failed on file /dev/stdout (No space left on device)
/opt/pihole/gravity.sh: line 505: echo: write error: No space left on device
[✓] Parsing domains into hosts format
[✓] Cleaning up stray matter
[✓] Force-reloading DNS service
[✓] DNS service is running
mibere
March 28, 2018, 6:19am
6
Don't forget there is also an operating system. Regarding used and free space take a look at the command
df -h
To free some space run sudo apt-get clean
pi@pi-hole:~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 1.8G 1.7G 12M 100% /
devtmpfs 484M 0 484M 0% /dev
tmpfs 489M 0 489M 0% /dev/shm
tmpfs 489M 25M 464M 6% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 489M 0 489M 0% /sys/fs/cgroup
/dev/mmcblk0p1 41M 21M 21M 51% /boot
tmpfs 98M 0 98M 0% /run/user/999
tmpfs 98M 0 98M 0% /run/user/1000
pi@pi-hole:~ $ sudo apt-get clean
pi@pi-hole:~ $ df -k
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 1811344 1641612 63424 97% /
devtmpfs 495548 0 495548 0% /dev
tmpfs 500156 0 500156 0% /dev/shm
tmpfs 500156 25396 474760 6% /run
tmpfs 5120 4 5116 1% /run/lock
tmpfs 500156 0 500156 0% /sys/fs/cgroup
/dev/mmcblk0p1 41853 21328 20525 51% /boot
tmpfs 100028 0 100028 0% /run/user/999
tmpfs 100028 0 100028 0% /run/user/1000
pi@pi-hole:~ $
Not much help. I guess I need a bigger sdcard.
To confirm, the out-of-space problem is why the existing lists are not being used? Can I pare down the lists, free up space, and get pihole working again?
I had a spare 32gb sdcard.
I ftp'd /etc/pihole/* to another machine.
I installed raspian and pi-hole on the 32gb sdcard, got it running, and put /etc/pihole/* back
(then I found teleporter, oh well)
I am now blocking 2,645,753 domains again.
Yeah, when you run out of space, all sorts of weird things start happening.
system
Closed
June 16, 2018, 11:40pm
10
