dolphin-emu.org is resolving since it's not blocked.
dolphin-emu.org not resolving (not blocked)
Can you please post the output of pihole -q --partial dolphin-emu.org?
Sure.
Please enter your password:
Please enter the correct second factor.
(Can be any number if you used the app password)
Found 0 domains partially matching 'dolphin-emu.org'.
Found 1 lists partially matching 'dolphin-emu.org'.
https://cdn.jsdelivr.net/gh/hagezi/dns-blocklists@latest/adblock/pro.txt (block)
||analytics.dolphin-emu.org^
And TY for the help
I do not see any blocks for it.
I even did the "disable blocking" for a bit and still no result.
nslookup just shows:
nslookup dolphin-emu.org
Server: 127.0.0.1
Address: 127.0.0.1#53 (direct on the ubuntu 24.04 server running pihole)
Non-authoritative answer:
*** Can't find dolphin-emu.org: No answer
or on Windows:
Server: pi.hole
Address: 192.168.10.164 (ip of pihole ubuntu 24.04 server)
Ok, just realized forgot to mention, sorry, I am using Cloudflared for DNS over TLS (DoT) support.
Sure enough, if i change to Google (ECS, DNSSEC) it works as expected.
Hell Ok, even works if I choose "Cloudflare (DNSSEC)".
Sorry had forgotten for a sec that Cloudflared was in play.
It looks like Cloudflared for DNS over TLS is blocking the domain.
Oops. Just realized.
cloudflared version 2024.8.3 (built 2024-08-22-1348 UTC)
ROFL, glad just a lab box in a VM behind a firewall lol.
Of course, updated to the latest, 2026.5.0 (built 2026-05-13-11:24 UTC)
And now working as expected, figures:
dig -p 5853 dolphin-emu.org
; <<>> DiG 9.18.39-0ubuntu0.24.04.3-Ubuntu <<>> -p 5853 dolphin-emu.org
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 11868
; COOKIE: fc1b44a60038ca9f (echoed)
;dolphin-emu.org. IN A
dolphin-emu.org. 35 IN A 37.19.207.38
;; Query time: 15 msec
;; SERVER: 127.0.0.1#5853(127.0.0.1) (UDP)
;; WHEN: Tue May 19 22:44:19 EDT 2026
;; MSG SIZE rcvd: 87
My bad, problem solved. Thanks anyways.
Solved by:
# Ubuntu 24.04 LTS (noble)
# Add cloudflare gpg key
sudo mkdir -p --mode=0755 /usr/share/keyrings
curl -fsSL https://pkg.cloudflare.com/cloudflare-main.gpg | sudo tee /usr/share/keyrings/cloudflare-main.gpg >/dev/null
# Add this repo to your apt repositories
echo 'deb [arch=amd64 signed-by=/usr/share/keyrings/cloudflare-main.gpg] https://pkg.cloudflare.com/cloudflared noble main' | sudo tee /etc/apt/sources.list.d/cloudflared.list
sudo apt-get update && sudo apt-get install cloudflared
Never mind that won't work either. As soon as you reboot, it will be broken.
Realised that cloudflared service failed to start.
It's because Cloudflare removed support for proxy-dns as per cloudflared proxy-dns command will be removed starting February 2, 2026 · Changelog
So yeah, CloudflareD is now dead for this use case. Bummer.
Thankfully, AdGuard's dnsproxy works great.
Adguard DNS Proxy:
wget ``https://github.com/AdguardTeam/dnsproxy/releases/download/v0.81.3/dnsproxy-linux-amd64-v0.81.3.tar.gz`` tar -xzf dnsproxy-linux-amd64-v0.81.3.tar.gz sudo mv linux-amd64/dnsproxy /usr/local/bin/ sudo chmod +x /usr/local/bin/dnsproxy
Create Service:
sudo tee /etc/systemd/system/dnsproxy.service << 'EOF'
[Unit]
Description=DNS Proxy (DoH)
After=network-online.target
Wants=network-online.target
[Service]
ExecStart=/usr/local/bin/dnsproxy -l 127.0.0.1 -p 5853 -u https://1.1.1.1/dns-query -u https://1.0.0.1/dns-query
Restart=on-failure
RestartSec=10
User=nobody
[Install]
WantedBy=multi-user.target
EOF
Enable Service:
sudo systemctl daemon-reload
sudo systemctl enable --now dnsproxy
sudo systemctl status dnsproxy
Verify:
https://one.one.one.one/help/
dig @127.0.0.1 -p 5853 google.com
dig google.com @127.0.0.1
sudo nmap -Pn -sT -sU -p 5853 127.0.0.1
sudo lsof -i :5853 -S
Stubby works well DNS Privacy Daemon - Stubby :: dnsprivacy.org
Same with dnsdist DNS-over-TLS - dnsdist documentation
Both have native packages so you don't need to download binaries and manually install them.
CoreDNS might also be worth a look: https://coredns.io/. It's a Swiss army knife sort of application/service, supporting various plugins. I don't use it to reach a DoH, but I do use it as a DoT proxy to my Pi-hole.
