jdrch
June 14, 2020, 3:20pm
1
Really dumb question, but I'll most likely have to apt purge mdadm
due to an associated boot problem . Ergo, I'm just checking for possible dependencies among things I didn't install from the Debian repos.
No, pihole doesn't need mdadm.
fi # We also need the correct version for `php-sqlite` (which differs across distros) if "${PKG_MANAGER}" install --dry-run "${phpVer}-sqlite3" > /dev/null 2>&1; then phpSqlite="sqlite3" else phpSqlite="sqlite" fi # Since our install script is so large, we need several other programs to successfully get a machine provisioned # These programs are stored in an array so they can be looped through later INSTALLER_DEPS=(dhcpcd5 git "${iproute_pkg}" whiptail) # Pi-hole itself has several dependencies that also need to be installed PIHOLE_DEPS=(cron curl dnsutils iputils-ping lsof netcat psmisc sudo unzip wget idn2 sqlite3 libcap2-bin dns-root-data libcap2) # The Web dashboard has some that also need to be installed # It's useful to separate the two since our repos are also setup as "Core" code and "Web" code PIHOLE_WEB_DEPS=(lighttpd "${phpVer}-common" "${phpVer}-cgi" "${phpVer}-${phpSqlite}" "${phpVer}-xml" "php-intl") # The Web server user, LIGHTTPD_USER="www-data" # group, LIGHTTPD_GROUP="www-data" # and config file LIGHTTPD_CFG="lighttpd.conf.debian"
