Ok, this is an odd question indeed.
I have a raspberry which run many services, including pi-hole. I've using it for a long, long time now. However, from time to time, my board just reboot.
At first I thought it was a power failure -> Changed the power source.
Afterwards, I start monitoring raspberry voltage -> Everything is ok.
I had this problem with ipv6 during two week, when I completely remove pi-hole. For my surprise, I got an uptime of 10 days.
I fixed the ipv6 problem, installed again, and there is a command for reboot.
Here is a piece of my syslog.
A first look points that everything start after:
/usr/local/bin/" pihole updatechecker local
Jul 2 19:22:43 rasp autossh[575]: timeout polling to accept read connection
Jul 2 19:22:43 rasp autossh[575]: port down, restarting ssh
Jul 2 19:22:43 rasp autossh[575]: starting ssh (count 1591)
Jul 2 19:22:43 rasp autossh[575]: ssh child pid is 11494
Jul 2 19:30:01 rasp CRON[14226]: (root) CMD ( PATH="$PATH:/usr/local/bin/" pihole updatechecker local)
Jul 2 19:30:46 rasp kernel: [969756.276119] Under-voltage detected! (0x00050005)
Jul 2 19:30:52 rasp kernel: [969762.516485] Voltage normalised (0x00000000)
Jul 2 19:32:40 rasp Node-RED[390]: 2 Jul 19:32:40 - [info] Stopping flows
Jul 2 19:32:40 rasp Node-RED[390]: 2 Jul 19:32:40 - [info] [mosca in:34c6e453.df2874] Unbinding mosca mqtt server from port: 1883
Jul 2 19:32:40 rasp Node-RED[390]: 2 Jul 19:32:40 - [info] serial port /dev/ttyACM0 closed
Jul 2 19:32:40 rasp Node-RED[390]: 2 Jul 19:32:40 - [info] [mqtt-broker:e1cd78d4.ca2998] Disconnected from broker: mqtt://localhost:1883
Jul 2 19:32:40 rasp Node-RED[390]: 2 Jul 19:32:40 - [info] serial port /dev/ttyUSB0 closed
Jul 2 19:32:43 rasp Node-RED[390]: 2 Jul 19:32:43 - [info] Stopped flows
Jul 2 19:32:43 rasp Node-RED[390]: 2 Jul 19:32:43 - [info] Starting flows
Jul 2 19:32:43 rasp Node-RED[390]: #033[32mTelegram Bot AiuroLarBot will be launched, environment is development#033[39m
Jul 2 19:32:43 rasp Node-RED[390]: #033[33mNo context provider specified for chatbot AiuroLarBot. Defaulting to "memory"#033[39m
Jul 2 19:32:45 rasp Node-RED[390]: 2 Jul 19:32:45 - [info] [python3-function:cbc944ac.a0e01] Python function '' running on PID 15240
Jul 2 19:32:45 rasp Node-RED[390]: 2 Jul 19:32:45 - [info] [mosca in:34c6e453.df2874] Binding mosca mqtt server on port: 1883
Jul 2 19:32:51 rasp Node-RED[390]: 2 Jul 19:32:51 - [info] Started flows
Jul 2 19:32:51 rasp Node-RED[390]: 2 Jul 19:32:51 - [error] serial port /dev/ttyACM0 error: Error: Error: No such file or directory, cannot open /dev/ttyACM0
Jul 2 19:32:51 rasp Node-RED[390]: 2 Jul 19:32:51 - [info] serial port /dev/ttyUSB0 opened at 9600 baud 8N1
Jul 2 19:32:52 rasp Node-RED[390]: 2 Jul 19:32:52 - [info] [mqtt-broker:e1cd78d4.ca2998] Connection failed to broker: mqtt://localhost:1883
Jul 2 19:32:55 rasp Node-RED[390]: 2 Jul 19:32:55 - [warn] [csv:ab4a3531.7f1e38] No columns template specified for object -> CSV.
Jul 2 19:32:58 rasp autossh[575]: timeout polling to accept read connection
Jul 2 19:32:58 rasp autossh[575]: port down, restarting ssh
Jul 2 19:32:58 rasp autossh[575]: starting ssh (count 1592)
Jul 2 19:32:58 rasp autossh[575]: ssh child pid is 15284
Jul 2 19:33:07 rasp Node-RED[390]: 2 Jul 19:33:07 - [info] [mqtt-broker:e1cd78d4.ca2998] Connected to broker: mqtt://localhost:1883
Jul 2 19:33:31 rasp systemd[1]: Started Session c33 of user thales.
Jul 2 19:34:08 rasp minissdpd[570]: device not found for removing : uuid:NFANDROID2-PRV-XIAOMIM12TRIAL-XIAOMMIBOX3-6728-FE23EBEE5C7120AEE92BDE4A046EF979DE70E9635AFC46415B6FEAB402D65818::upnp:rootdevice
Jul 2 19:34:08 rasp minissdpd[570]: device not found for removing : uuid:NFANDROID2-PRV-XIAOMIM12TRIAL-XIAOMMIBOX3-6728-FE23EBEE5C7120AEE92BDE4A046EF979DE70E9635AFC46415B6FEAB402D65818::urn:schemas-upnp-org:device:mdxdevice:1
Jul 2 19:34:08 rasp minissdpd[570]: device not found for removing : uuid:NFANDROID2-PRV-XIAOMIM12TRIAL-XIAOMMIBOX3-6728-FE23EBEE5C7120AEE92BDE4A046EF979DE70E9635AFC46415B6FEAB402D65818::urn:mdx-netflix-com:service:target:3
Jul 2 19:34:16 rasp systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jul 2 19:34:16 rasp systemd[1]: Stopped target RPC Port Mapper.
Jul 2 19:34:16 rasp systemd[1]: session-c22.scope: Killing process 31714 (pihole-FTL) with signal SIGTERM.
Jul 2 19:34:16 rasp systemd[1]: Stopping Session c22 of user pihole.
Jul 2 19:34:16 rasp systemd[1]: Stopped target Bluetooth.
Jul 2 19:34:16 rasp systemd[1]: Stopping Session c33 of user thales.
Jul 2 19:34:16 rasp systemd[1]: Stopped target Sound Card.
Jul 2 19:34:16 rasp systemd[1]: Stopping User Manager for UID 999...
Jul 2 19:34:16 rasp systemd[1]: session-c19.scope: Killing process 27625 (ipUpdate.pl) with signal SIGTERM.
Jul 2 19:34:16 rasp systemd[1]: Stopping Session c19 of user thales.
Jul 2 19:34:16 rasp systemd[1]: Stopping Save/Restore Sound Card State...
Jul 2 19:34:16 rasp systemd[1]: Stopped target Timers.
Jul 2 19:34:16 rasp systemd[1]: Stopped Daily apt upgrade and clean activities.
Jul 2 19:34:16 rasp systemd[1]: Stopped Daily apt download activities.
Jul 2 19:34:16 rasp systemd[1]: Stopped target Graphical Interface.
Jul 2 19:34:16 rasp systemd[1]: Stopped target Multi-User System.
Jul 2 19:34:16 rasp systemd[1]: Stopping triggerhappy global hotkey daemon...
Jul 2 19:34:16 rasp systemd[1]: Stopping Regular background program processing daemon...
Jul 2 19:34:16 rasp systemd[1]: Stopping LSB: pihole-FTL daemon...
Jul 2 19:34:16 rasp systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Jul 2 19:34:16 rasp Node-RED[390]: 2 Jul 19:34:16 - [info] Stopping flows
Jul 2 19:34:16 rasp systemd[1]: Stopping uptime record daemon...
Jul 2 19:34:16 rasp systemd[1]: Stopping keep memory of all UPnP devices that announced themselves...
Jul 2 19:34:16 rasp systemd[1]: Stopping Node-RED graphical event wiring tool...
Jul 2 19:34:16 rasp systemd[1]: Stopping Configure Bluetooth Modems connected by UART...
