Folks,
Think Pi-Hole is working but a couple of issues makes me think I might have installed incorrectly.
From the dashboard - settings I cannot 'flush logs'. No error displayed but on returning to Dashboard display still shows all previous data.
pi-hole -f from the command line works fine with no sudo
I installed by viewing the installation script first, saving it, setting it to execute, put script in home directory then sudo ./pi-hole-install.sh (which is what I named the file).
Is there a problem here?
Previous post on similar issue link below.
Geffers
