dear all
I have MikroTik RB5009UG+S+ (192.168.8.1) hotspot server and I have 2 Huawei 5g CPE N5368X (192.168.1.1) and (192.168.2.1) connected to MK and I set it up LOAD BALANCING NTH
I follow instruction to install container on this video Docker containers on Mikrotik? Part 2 - YouTube to use pihole but when I write to my MK ip (192.168.8.1:888) on browser the pihole page not open or i got this
I need your help please
with regards
Append /admin
to the URL.
Alternatively, set the environment variable FTLCONF_LOCAL_IPV4
to 192.168.8.1
, and it should automatically redirect
Always read the release notes:
thank you for your help.
but can you please give more details how to do that please?
with regards
I have never set up a container on a mikrotik router before - but take a look at the video you yourself linked... (hint: timestamp is about 3:19)
thank its work but with error
You can try setting the env variable DNSMASQ_USER
to root
- that is a requirement on some systems.
See the README here for a list of the environment variables that you can use
PromoFaux THANK YOU SO MUTCH it's WORKING NOW
as I mention that I have Huawei 5G router which is connected to MK RB5009
NO ONE even mention that I have to change the DNS from Huawei router to Pihole DNS
The router configuration is mentioned on the Documentation:
Post-Install: Post-Install - Pi-hole documentation
