I just attempted a deploy on RPi4 running AlmaLinux 8 with the following docker-compose file:
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
- "53:53/tcp"
- "53:53/udp"
- "67:67/udp"
- "80:80/tcp"
environment:
TZ: 'America/New_York'
PIHOLE_DNS_: 208.67.222.222;8.8.8.8
volumes:
- '/mnt/docker:/etc/pihole/'
- '/mnt/docker:/etc/dnsmasq.d/'
restart: unless-stopped
After deploy I am seeing this in the logs:
pihole | Starting pihole-FTL (no-daemon) as pihole
pihole | Stopping pihole-FTL
pihole | pihole-FTL: no process found
I can log into the web interface but there is an error in the Pi-hole Diagnosis that states this:
2022-03-08 04:14:08 DNSMASQ_CONFIG FTL failed to start due to bad option at line 1 of /etc/dnsmasq.d/GitHubVersions
Can someone tell what the issue may be?
Looking at the 'GitHubVersions' file I see this: v5.9 v5.11 v5.14
Just for awareness, I did have Pi-hole running at one time on RPi4 running AlmaLinux 8 but I wasn't using docker then, it was just a straight install of Pi-hole.
Thanks.
