Hi all,
I'm using Pi-hole v5.0 with Unbound 1.10.1 (compiled), with this unbound.conf settings:
server:
# mandatory settings - do not change
tls-cert-bundle: "/etc/ssl/certs/ca-certificates.crt"
chroot: "/etc/unbound"
username: "unbound"
directory: "/etc/unbound"
#logfile: "unbound.log"
root-hints: "root.hints"
pidfile: "unbound.pid"
auto-trust-anchor-file: "root.key"
# end of mandatory settings# recommended settings # outgoing-range: 8192 # num-queries-per-thread: 4096 # so-rcvbuf: 4M # so-sndbuf: 4M # access-control: 127.0.0.0/8 allow # end of recommended settings interface: 127.0.0.1 interface: ::1 port: 5335 do-ip4: yes do-udp: yes do-tcp: yes # May be set to yes if you have IPv6 connectivity do-ip6: yes # You want to leave this to no unless you have *native* IPv6. With 6to4 and # Terredo tunnels your web browser should favor IPv4 for the same reasons prefer-ip6: yes # Trust glue only if it is within the server's authority harden-glue: yes # Require DNSSEC data for trust-anchored zones, if such data is absent, the zone becomes BOGUS harden-dnssec-stripped: yes # Aggressive NSEC uses the DNSSEC NSEC chain to synthesize NXDOMAIN # and other denials, using information from previous NXDOMAINs answers. aggressive-nsec: yes # Don't use Capitalization randomization as it known to cause DNSSEC issues sometimes # see https://discourse.pi-hole.net/t/unbound-stubby-or-dnscrypt-proxy/9378 for further details use-caps-for-id: no # Reduce EDNS reassembly buffer size. # Suggested by the unbound man page to reduce fragmentation reassembly problems edns-buffer-size: 1472 # Perform prefetching of close to expired message cache entries # This only applies to domains that have been frequently queried prefetch: yes # One thread should be sufficient, can be increased on beefy machines. In reality for most users running on small networks or on a single machine, it should be unnecessary to seek performance enhancement by increasing num$ #num-threads: 1 # Ensure kernel buffer is large enough to not lose messages in traffic spikes so-rcvbuf: 1m # Ensure privacy of local IP ranges private-address: 192.168.0.0/16 private-address: 169.254.0.0/16 private-address: 172.16.0.0/12 private-address: 10.0.0.0/8 #private-address: fd00::/8 #private-address: fe80::/10 cache-min-ttl: 0 serve-expired: yes msg-cache-size: 128m rrset-cache-size: 256m # Send minimum amount of information to upstream servers to enhance # privacy. Only sends minimum required labels of the QNAME and sets # QTYPE to NS when possible. # See RFC 7816 "DNS Query Name Minimisation to Improve Privacy" for # details. # https://ripe72.ripe.net/presentations/120-unbound_qnamemin_ripe72.pdf # test: drill txt qnamemintest.internet.nl # result: "HOORAY - QNAME minimisation is enabled on your resolver :)!" qname-minimisation: yes harden-below-nxdomain: yes
remote-control:
control-enable: yes
control-interface: 127.0.0.1auth-zone:
# local copy of the DNS root zone (hyperlocal)
# Use servers that provide zone transfer of the root zone (AXFR), see
# https://root-servers.org/faq.html and
# Zone transfer | ICANN DNS Engineering
master: 192.5.5.241 # f.root-servers.net
master: 2001:500:2f::f # f.root-servers.net
master: 192.0.32.132 # lax.xfr.dns.icann.org
master: 192.0.47.132 # iad.xfr.dns.icann.org
master: 2620:0:2d0:202::132 # lax.xfr.dns.icann.org
master: 2620:0:2830:202::132 # iad.xfr.dns.icann.org
# Additional download via URL:
url: "https://www.internic.net/domain/root.zone"
fallback-enabled: yes
for-downstream: no
for-upstream: yes
zonefile: "root.zone"
(no other conf files used)
I also enabled DNSSEC in Pi-hole settings, and I use Pi-hole as DNS Server (not DHCP server).
Now, after restarting the raspberry pi (Pi Zero W), when testing DNSSEC validation, the tests sometimes indicate that DNSSEC validation is working and sometimes that it is not. Test sites used include https://dnssec.vs.uni-due.de/ , http://www.dnssec-or-not.com/ and Connection test .
Debug log is here: https://tricorder.pi-hole.net/w64hjqyprs
What could be the reason for this? Testing with dig on the raspberry pi does give the right responses.
Thanks for your input in advance!
