Getting a dnsmasq warning: Working around kernel bug: faulty source address scope for VRF slave eth0
Why am I getting this?
Also, had problems with a corrupted pi-hole version file recently. What's going on?
Time to look in the box itself : What does the config file look like ? ![]()
I am betting on the file being corrupted and your microSDXC card needs to be replaced.
Which config file specifically?
Network booting NFS mounted file system. No microSD card.
Also, occurred recently on two different machines (one of which is using a microSD card).
VRF slave of eth0 = Your network config
Any kind of storage can have issues so I would check that anyway just to be sure! ![]()
