You are right, there is a file called /etc/dnsmasq.d/99-pihole-colleague-lists.conf containing the line 'conf-file=~/pihole-lists/domains.txt' Should I just delete that file?
If you don't know why it's there then remove the whole file. Do not rename it, it will still be read and used.
By god that did it. Thank you for all your time, all of you! Not sure what to mark as the "solution" for this one...
