Tried on my rpi, tried on my tinkerboard, tried with docker, tried with manual install. Just spinning circles and no DNS service running : (
Are there any errors in /var/log/pihole-FTL.log?
Reinstalled again and for some reason things seem to load and DNS shows enabled, but the dashboard is all loading circles still... new debug:
https://tricorder.pi-hole.net/yj2zzyb2v4
No obvious errors in pihole-FTL.log >
root@DietPi:/var/log# cat pihole-FTL.log
[2020-09-21 19:24:38.840 600M] Using log file /var/log/pihole-FTL.log
[2020-09-21 19:24:38.840 600M] ########## FTL started! ##########
[2020-09-21 19:24:38.840 600M] FTL branch: master
[2020-09-21 19:24:38.840 600M] FTL version: v5.2
[2020-09-21 19:24:38.840 600M] FTL commit: dbd4a69
[2020-09-21 19:24:38.840 600M] FTL date: 2020-08-09 22:09:43 +0100
[2020-09-21 19:24:38.840 600M] FTL user: pihole
[2020-09-21 19:24:38.840 600M] Compiled for armhf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2020-09-21 19:24:38.841 600M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-09-21 19:24:38.841 600M] SOCKET_LISTENING: only local
[2020-09-21 19:24:38.841 600M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-09-21 19:24:38.841 600M] MAXDBDAYS: max age for stored queries is 365 days
[2020-09-21 19:24:38.841 600M] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-09-21 19:24:38.841 600M] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-09-21 19:24:38.841 600M] DBINTERVAL: saving to DB file every minute
[2020-09-21 19:24:38.841 600M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-09-21 19:24:38.841 600M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-09-21 19:24:38.841 600M] PRIVACYLEVEL: Set to 0
[2020-09-21 19:24:38.841 600M] IGNORE_LOCALHOST: Show queries from localhost
[2020-09-21 19:24:38.841 600M] BLOCKINGMODE: Null IPs for blocked domains
[2020-09-21 19:24:38.841 600M] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2020-09-21 19:24:38.841 600M] DBIMPORT: Importing history from database
[2020-09-21 19:24:38.841 600M] PIDFILE: Using /run/pihole-FTL.pid
[2020-09-21 19:24:38.841 600M] PORTFILE: Using /run/pihole-FTL.port
[2020-09-21 19:24:38.841 600M] SOCKETFILE: Using /run/pihole/FTL.sock
[2020-09-21 19:24:38.841 600M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-09-21 19:24:38.841 600M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-09-21 19:24:38.841 600M] GRAVITYDB: Using /etc/pihole/gravity.db
[2020-09-21 19:24:38.841 600M] PARSE_ARP_CACHE: Active
[2020-09-21 19:24:38.841 600M] CNAME_DEEP_INSPECT: Active
[2020-09-21 19:24:38.841 600M] DELAY_STARTUP: No delay requested.
[2020-09-21 19:24:38.841 600M] NICE: Set process niceness to -10 (default)
[2020-09-21 19:24:38.841 600M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-09-21 19:24:38.841 600M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2020-09-21 19:24:38.841 600M] Finished config file parsing
[2020-09-21 19:24:38.844 600M] Database version is 7
[2020-09-21 19:24:38.845 600M] Database successfully initialized
[2020-09-21 19:24:38.845 600M] Imported 0 queries from the long-term database
[2020-09-21 19:24:38.845 600M] -> Total DNS queries: 0
[2020-09-21 19:24:38.845 600M] -> Cached DNS queries: 0
[2020-09-21 19:24:38.845 600M] -> Forwarded DNS queries: 0
[2020-09-21 19:24:38.845 600M] -> Blocked DNS queries: 0
[2020-09-21 19:24:38.845 600M] -> Unknown DNS queries: 0
[2020-09-21 19:24:38.845 600M] -> Unique domains: 0
[2020-09-21 19:24:38.845 600M] -> Unique clients: 0
[2020-09-21 19:24:38.845 600M] -> Known forward destinations: 0
[2020-09-21 19:24:38.845 600M] Successfully accessed setupVars.conf
[2020-09-21 19:24:38.853 608M] PID of FTL process: 608
[2020-09-21 19:24:38.854 608M] Reloading DNS cache
[2020-09-21 19:24:38.854 608/T611] Listening on Unix socket
[2020-09-21 19:24:38.854 608/T609] Listening on port 4711 for incoming IPv4 telnet connections
[2020-09-21 19:24:38.855 608/T610] Listening on port 4711 for incoming IPv6 telnet connections
[2020-09-21 19:24:38.855 608M] Blocking status is enabled
[2020-09-21 19:24:38.919 608M] INFO: No regex blacklist entries found
[2020-09-21 19:24:38.919 608M] INFO: No regex whitelist entries found
[2020-09-21 19:24:38.919 608M] Compiled 0 whitelist and 0 blacklist regex filters for 0 clients in 1.7 msec
The difference to your previous debug log is that FTL is now running and has answered queries
[53] is in use by pihole-FTL
[80] is in use by lighttpd
[80] is in use by lighttpd**
query[A] www.nanawardrobe.pl from 127.0.0.1
Sep 21 19:29:51 dnsmasq[608]: gravity blocked www.nanawardrobe.pl is 0.0.0.0
If the dashboard is still showing spinning circles, clear your browser cache or try another browser.
