With the latest Docker image, I'm seeing a message in the WebUI about "DNS service not running". The same message is repeated in the container startup logs: [✗] DNS service is NOT listening
This same compose file was happily running before, and I haven't made changes.
Running pihole -d
inside the container, I see 2 red items.
192.168.1.11/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
This seems like not really a problem. ServerIP is set to 192.168.1.11. Setting it to 192.168.1.11/24 and the container fails to start.
[✗] lighttpd daemon is inactive
[✗] pihole-FTL daemon is inactive
I don't really believe either of these, since ps aux
shows both processes as up and running. So maybe there some detection of this that's not happening?
