I guess all leds in web UI should be green.
red light for - DNS service not running
red light for - FTL offline
On clicking Enable, DNS servise will turn green, but on refresh will be back red.
qm0wfqvlgf
I tried different solutions that I read related to "DNS service not running" and "FTL offline" - but it didn't help.
From what I read I think it may be this (because it is a KANO - customized Raspberry Pi): "Your kernel/filesystem does not support the capabilities required for letting FTL bind to the right ports when running under a non-root user".
But I am not sure,
Your OS is likely not supported. There are a number of problems seen in your debug log.
[✗] No IPv4 address(es) found on the eth0 interface.
[✗] No IPv6 address(es) found on the eth0 interface.
* Pinging 192.168.1.1...
[✓] lerofa.hol.es is 31.220.19.67 via localhost (127.0.0.1)
[✗] Failed to resolve lerofa.hol.es via Pi-hole (192.168.1.196)
Mar 26 01:17:07 dnsmasq[859]: failed to load names from /etc/pihole/black.list: No such file or directory
[✗] Mar 26 01:17:07 dnsmasq[859]: bad address at /etc/pihole/gravity.list line 2 (https://discourse.pi-hole.net/t/why-do-i-see-bad-address-at-in-pihole-log/3972)
[✗] Mar 26 01:17:07 dnsmasq[859]: bad address at /etc/pihole/gravity.list line 3 (https://discourse.pi-hole.net/t/why-do-i-see-bad-address-at-in-pihole-log/3972)
[✗] Mar 26 01:17:07 dnsmasq[859]: bad address at /etc/pihole/gravity.list line 4 (https://discourse.pi-hole.net/t/why-do-i-see-bad-address-at-in-pihole-log/3972)
but os_release say the OS it is Raspbian GNU/Linux 9 (stretch) - I guess this OS should be supported.
Or there are customizations that were made on top of it , because of KANO.
