DNS service not running and FTL offline after last update
I do see that pihole-FTL is currently running, so that is good.
Reboot doesn't do anything.
Maybe i just reinstall the OS?
Probably the easiest way.
If you can, then that is a good way to make sure everything is set correctly. I would suggest Raspbian Stretch though instead of Jessie, since Jessie has reached End Of Life status.
Ok will do.
Huge thanks for anyone who tried to help.
Really appreciate your work.
