Hello !
I 've been using pihole for about two months on a raspberry pi 3b to filter ads in my home network and everything worked fine. Yesterday I updated the raspberry to the latest kernel 4.19.75-v7+ and now I cant start DNS service.
That seems to work (I get a green check mark), but pihole status reports that DNS service is not running.
to "sudo service pihole-FTL restartand get no errors,sudo service pihole-FTL status` reports the following:
â—Ź pihole-FTL.service - LSB: pihole-FTL daemon
Active: active (exited) since Sun 2019-10-13 13:52:50 BST; 3min 22s ago
Process: 14689 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Oct 13 13:52:50 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Oct 13 13:52:50 raspberrypi pihole-FTL[14689]: Not running
Oct 13 13:52:50 raspberrypi su[14716]: (to pihole) root on none
Oct 13 13:52:50 raspberrypi su[14716]: pam_unix(su:session): session opened for user pihole by (uid=0)
Oct 13 13:52:50 raspberrypi pihole-FTL[14689]: dnsmasq: failed to create listening socket for port 53: Address already in use
Oct 13 13:52:50 raspberrypi su[14716]: pam_unix(su:session): session closed for user pihole
Oct 13 13:52:50 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
... but nothing changed !
I tried "pihole -r" and didn't change anything.
I tried "pihole checkout master" (after changing resolv.conf to 1.1.1.1) - and nothing got better ...
pihole-FTL cannot bind to port 53 because there is another process running on that port. Run the following command from the Pi terminal and post the output - this will show all processes running on ports used by Pi-Hole and software that may be run alongside Pi-Hole:
As you can see, I use stubby to send encrypted dns-requests - but it uses 127.0.0.2:53, not 127.0.0.1 and it was no problem before kernel update.
I also have another issue: the HTML-user-interface of pihole doesn't work properly anymore - I get the "LOST CONNECTION TO API"-error when trying to connect to the 192.168.3.36/admin page.
Okay, this seems to solve the problem ! DNS can be restarted after stopping stubby, and even after restarting stubby everything works fine !
pi@raspberrypi:~ $ sudo systemctl stop stubby
pi@raspberrypi:~ $ sudo systemctl status stubby
â—Ź stubby.service - stubby DNS resolver
Loaded: loaded (/lib/systemd/system/stubby.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Sun 2019-10-13 17:18:26 BST; 5s ago
Process: 522 ExecStart=/usr/local/bin/stubby (code=killed, signal=TERM)
Main PID: 522 (code=killed, signal=TERM)
Oct 13 14:19:01 raspberrypi stubby[522]: [13:19:01.964525] STUBBY: DNSSEC Validation is ON
Oct 13 14:19:01 raspberrypi stubby[522]: [13:19:01.964561] STUBBY: Transport list is:
Oct 13 14:19:01 raspberrypi stubby[522]: [13:19:01.964574] STUBBY: - TLS
Oct 13 14:19:01 raspberrypi stubby[522]: [13:19:01.964586] STUBBY: Privacy Usage Profile is Strict (Authentication required)
Oct 13 14:19:01 raspberrypi stubby[522]: [13:19:01.964597] STUBBY: (NOTE a Strict Profile only applies when TLS is the ONLY transpor
Oct 13 14:19:01 raspberrypi stubby[522]: [13:19:01.964628] STUBBY: Starting DAEMON....
Oct 13 17:18:25 raspberrypi systemd[1]: Stopping stubby DNS resolver...
Oct 13 17:18:26 raspberrypi systemd[1]: stubby.service: Main process exited, code=killed, status=15/TERM
Oct 13 17:18:26 raspberrypi systemd[1]: stubby.service: Succeeded.
Oct 13 17:18:26 raspberrypi systemd[1]: Stopped stubby DNS resolver.
pi@raspberrypi:~ $ sudo service pihole-FTL restart
pi@raspberrypi:~ $ pihole status
[âś“] DNS service is running
[âś“] Pi-hole blocking is Enabled
pi@raspberrypi:~ $ sudo systemctl start stubby
pi@raspberrypi:~ $
Thanks a lot !! (And how can I format the output in the way you did with my replies ?)
Edit your post, highlight/select the portion of text that you want to format as code. On the top row of the reply window, select the format option </> and this will format that output as code. Save and that's it.
Oct 13 14:19:01 raspberrypi stubby[522]: [13:19:01.964628] STUBBY: Starting DAEMON…
Oct 13 17:18:25 raspberrypi systemd[1]: Stopping stubby DNS resolver…
pi@raspberrypi:~ $
