DNS service is NOT running Ubuntu 19.10
DNS service should run
DNS service is NOT runnig
w7zqbhneae
After an upgrade from Ubuntu 18.04 to 19.10 FTL is not starting anymore.
Reconfiguring and new installation have not helped in any case.
Debug token attached.
I would be thankful for any help.
Thanks a lot.
Ubuntu 19 is not a supported OS.
https://docs.pi-hole.net/main/prerequesites/
What does sudo systemctl status --full --no-pager pihole-FTL.service show?
mattes@dns-vpn:~$ sudo systemctl status --full --no-pager pihole-FTL.service
[sudo] password for mattes:
â—Ź pihole-FTL.service - LSB: pihole-FTL daemon
Active: active (exited) since Sun 2020-04-05 01:01:04 CEST; 7h ago
Process: 12604 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Apr 05 01:01:02 dns-vpn systemd[1]: Starting LSB: pihole-FTL daemon...
Apr 05 01:01:03 dns-vpn pihole-FTL[12604]: Not running
Apr 05 01:01:03 dns-vpn su[12636]: (to pihole) root on none
Apr 05 01:01:03 dns-vpn su[12636]: pam_unix(su:session): session opened for user pihole by (uid=0)
Apr 05 01:01:04 dns-vpn pihole-FTL[12604]: dnsmasq: cannot access /etc/dnsmasq.d/lxd: No such file or directory
Apr 05 01:01:04 dns-vpn systemd[1]: Started LSB: pihole-FTL daemon.
I finally got it back to work.
$ ll /etc/dnsmasq.d/lxd
lrwxrwxrwx 1 root root 28 Feb 3 19:24 /etc/dnsmasq.d/lxd -> /etc/dnsmasq.d-available/lxd
The file was linked to the not existing folder /etc/dnsmasq.d-available/. I removed the link and everything is running fine.
DanSharper: Thanks for your support. I love Pi-Hole for years and it was my first „big“ issue.
Is this something new with lxd 4? We normally don't support virtualization on the host, most of the use cases are with Pi-hole virtualized as the guest.
No idea. I don’t use virtualisation on this host, what makes it much more suspicious. But for what ever reason it happend, luckily it’s solved. :wink:
1st. Thank you. This was 100% my issue and this solved it.
For clarity, I:
  1. sudo systemctl status --full --no-pager pihole-FTL.service
  2. Confirmed that it was getting stuck at LXD
  3. them just rm /etc/dnsmasq.d/lxd
  4. reboot
This happened to me when I updated from 18 to 20 (ubuntu).
