My ufw rules are still up.
The IP of Pi-Hole's docker container is the following 172.18.0.2, ran:
sudo docker exec pihole cat /etc/hosts
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
172.18.0.2 42ee74fe7f2e
And this is the entire json from docker container inspect pihole command:
"Id": "42ee74fe7f2e0dda521908f06367f81308097a0fee33b155de41c37bf5875f0a",
"Created": "2021-03-02T14:42:00.554466225Z",
"Path": "/s6-init",
"Args": [],
"State": {
"Status": "running",
"Running": true,
"Paused": false,
"Restarting": false,
"OOMKilled": false,
"Dead": false,
"Pid": 93377,
"ExitCode": 0,
"Error": "",
"StartedAt": "2021-03-02T14:42:02.272884366Z",
"FinishedAt": "0001-01-01T00:00:00Z",
"Health": {
"Status": "healthy",
"FailingStreak": 0,
"Log": [
"Start": "2021-03-06T10:06:35.542365978Z",
"End": "2021-03-06T10:06:35.731958387Z",
"ExitCode": 0,
"Output": "\n; <<>> DiG 9.11.5-P4-5.1+deb10u2-Debian <<>> +norecurse +retry=0 @127.0.0.1 pi.hole\n; (1 server found)\n;; global options: +cmd\n;; Got answer:\n;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 61775\n;; flags: qr aa ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1\n\n;; OPT PSEUDOSECTION:\n; EDNS: version: 0, flags:; udp: 4096\n;; QUESTION SECTION:\n;pi.hole.\t\t\tIN\tA\n\n;; ANSWER SECTION:\npi.hole.\t\t2\tIN\tA\t0.0.0.0\n\n;; Query time: 0 msec\n;; SERVER: 127.0.0.1#53(127.0.0.1)\n;; WHEN: Sat Mar 06 11:06:35 CET 2021\n;; MSG SIZE rcvd: 52\n\n"
"Start": "2021-03-06T10:07:05.743832532Z",
"End": "2021-03-06T10:07:05.9218578Z",
"ExitCode": 0,
"Output": "\n; <<>> DiG 9.11.5-P4-5.1+deb10u2-Debian <<>> +norecurse +retry=0 @127.0.0.1 pi.hole\n; (1 server found)\n;; global options: +cmd\n;; Got answer:\n;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 57291\n;; flags: qr aa ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1\n\n;; OPT PSEUDOSECTION:\n; EDNS: version: 0, flags:; udp: 4096\n;; QUESTION SECTION:\n;pi.hole.\t\t\tIN\tA\n\n;; ANSWER SECTION:\npi.hole.\t\t2\tIN\tA\t0.0.0.0\n\n;; Query time: 0 msec\n;; SERVER: 127.0.0.1#53(127.0.0.1)\n;; WHEN: Sat Mar 06 11:07:05 CET 2021\n;; MSG SIZE rcvd: 52\n\n"
"Start": "2021-03-06T10:07:35.932180569Z",
"End": "2021-03-06T10:07:36.114859719Z",
"ExitCode": 0,
"Output": "\n; <<>> DiG 9.11.5-P4-5.1+deb10u2-Debian <<>> +norecurse +retry=0 @127.0.0.1 pi.hole\n; (1 server found)\n;; global options: +cmd\n;; Got answer:\n;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 60052\n;; flags: qr aa ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1\n\n;; OPT PSEUDOSECTION:\n; EDNS: version: 0, flags:; udp: 4096\n;; QUESTION SECTION:\n;pi.hole.\t\t\tIN\tA\n\n;; ANSWER SECTION:\npi.hole.\t\t2\tIN\tA\t0.0.0.0\n\n;; Query time: 0 msec\n;; SERVER: 127.0.0.1#53(127.0.0.1)\n;; WHEN: Sat Mar 06 11:07:36 CET 2021\n;; MSG SIZE rcvd: 52\n\n"
"Start": "2021-03-06T10:08:06.124819805Z",
"End": "2021-03-06T10:08:06.312969304Z",
"ExitCode": 0,
"Output": "\n; <<>> DiG 9.11.5-P4-5.1+deb10u2-Debian <<>> +norecurse +retry=0 @127.0.0.1 pi.hole\n; (1 server found)\n;; global options: +cmd\n;; Got answer:\n;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 48348\n;; flags: qr aa ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1\n\n;; OPT PSEUDOSECTION:\n; EDNS: version: 0, flags:; udp: 4096\n;; QUESTION SECTION:\n;pi.hole.\t\t\tIN\tA\n\n;; ANSWER SECTION:\npi.hole.\t\t2\tIN\tA\t0.0.0.0\n\n;; Query time: 0 msec\n;; SERVER: 127.0.0.1#53(127.0.0.1)\n;; WHEN: Sat Mar 06 11:08:06 CET 2021\n;; MSG SIZE rcvd: 52\n\n"
"Start": "2021-03-06T10:08:36.323462202Z",
"End": "2021-03-06T10:08:36.507519406Z",
"ExitCode": 0,
"Output": "\n; <<>> DiG 9.11.5-P4-5.1+deb10u2-Debian <<>> +norecurse +retry=0 @127.0.0.1 pi.hole\n; (1 server found)\n;; global options: +cmd\n;; Got answer:\n;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 35610\n;; flags: qr aa ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1\n\n;; OPT PSEUDOSECTION:\n; EDNS: version: 0, flags:; udp: 4096\n;; QUESTION SECTION:\n;pi.hole.\t\t\tIN\tA\n\n;; ANSWER SECTION:\npi.hole.\t\t2\tIN\tA\t0.0.0.0\n\n;; Query time: 0 msec\n;; SERVER: 127.0.0.1#53(127.0.0.1)\n;; WHEN: Sat Mar 06 11:08:36 CET 2021\n;; MSG SIZE rcvd: 52\n\n"
"Image": "sha256:30ed4cf3e0dd2c5065d94c841212b478162e02757aba34afa36369ea8861bb55",
"ResolvConfPath": "/var/lib/docker/containers/42ee74fe7f2e0dda521908f06367f81308097a0fee33b155de41c37bf5875f0a/resolv.conf",
"HostnamePath": "/var/lib/docker/containers/42ee74fe7f2e0dda521908f06367f81308097a0fee33b155de41c37bf5875f0a/hostname",
"HostsPath": "/var/lib/docker/containers/42ee74fe7f2e0dda521908f06367f81308097a0fee33b155de41c37bf5875f0a/hosts",
"LogPath": "/var/lib/docker/containers/42ee74fe7f2e0dda521908f06367f81308097a0fee33b155de41c37bf5875f0a/42ee74fe7f2e0dda521908f06367f81308097a0fee33b155de41c37bf5875f0a-json.log",
"Name": "/pihole",
"RestartCount": 0,
"Driver": "overlay2",
"Platform": "linux",
"MountLabel": "",
"ProcessLabel": "",
"AppArmorProfile": "docker-default",
"ExecIDs": null,
"HostConfig": {
"Binds": [
"/home/nako/pi-hole/etc-dnsmasq.d:/etc/dnsmasq.d:rw",
"/home/nako/pi-hole/etc-pihole:/etc/pihole:rw"
"ContainerIDFile": "",
"LogConfig": {
"Type": "json-file",
"Config": {}
"NetworkMode": "pi-hole_default",
"PortBindings": {
"443/tcp": [
"HostIp": "",
"HostPort": "443"
"53/tcp": [
"HostIp": "",
"HostPort": "53"
"53/udp": [
"HostIp": "",
"HostPort": "53"
"67/udp": [
"HostIp": "",
"HostPort": "67"
"80/tcp": [
"HostIp": "",
"HostPort": "80"
"RestartPolicy": {
"Name": "unless-stopped",
"MaximumRetryCount": 0
"AutoRemove": false,
"VolumeDriver": "",
"VolumesFrom": [],
"CapAdd": [
"NET_ADMIN"
"CapDrop": null,
"CgroupnsMode": "host",
"Dns": [
"127.0.0.1",
"1.1.1.1"
"DnsOptions": null,
"DnsSearch": null,
"ExtraHosts": null,
"GroupAdd": null,
"IpcMode": "shareable",
"Cgroup": "",
"Links": null,
"OomScoreAdj": 0,
"PidMode": "",
"Privileged": false,
"PublishAllPorts": false,
"ReadonlyRootfs": false,
"SecurityOpt": null,
"UTSMode": "",
"UsernsMode": "",
"ShmSize": 67108864,
"Runtime": "runc",
"ConsoleSize": [
0,
0
"Isolation": "",
"CpuShares": 0,
"Memory": 0,
"NanoCpus": 0,
"CgroupParent": "",
"BlkioWeight": 0,
"BlkioWeightDevice": null,
"BlkioDeviceReadBps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteIOps": null,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpusetCpus": "",
"CpusetMems": "",
"Devices": null,
"DeviceCgroupRules": null,
"DeviceRequests": null,
"KernelMemory": 0,
"KernelMemoryTCP": 0,
"MemoryReservation": 0,
"MemorySwap": 0,
"MemorySwappiness": null,
"OomKillDisable": null,
"PidsLimit": null,
"Ulimits": null,
"CpuCount": 0,
"CpuPercent": 0,
"IOMaximumIOps": 0,
"IOMaximumBandwidth": 0,
"MaskedPaths": [
"/proc/asound",
"/proc/acpi",
"/proc/kcore",
"/proc/keys",
"/proc/latency_stats",
"/proc/timer_list",
"/proc/timer_stats",
"/proc/sched_debug",
"/proc/scsi",
"/sys/firmware"
"ReadonlyPaths": [
"/proc/bus",
"/proc/fs",
"/proc/irq",
"/proc/sys",
"/proc/sysrq-trigger"
"GraphDriver": {
"Data": {
"LowerDir": "/var/lib/docker/overlay2/5b47455a100e18ad5b4061e103e25bbb6a01668de7286325d4026504e0927bcf-init/diff:/var/lib/docker/overlay2/e82e51b32b437f106d2c4562df9597d917463cb3839c6e52c617296884e726f1/diff:/var/lib/docker/overlay2/eeaf9f8b9996c1178a9a0f740cdcd4d4721f829e9aa0d5cc6397041733ce59e0/diff:/var/lib/docker/overlay2/f0f892218a27557339f076aee450c1b748a15e310a5308673dc698ea9ad20dc0/diff:/var/lib/docker/overlay2/128289f69d29415ffe1f64a27a326222e296585358176e103c675ee8a98a50cb/diff:/var/lib/docker/overlay2/1aeac86e7554097c947ae3cf120c3975c3118818c610d96cd3cc3ec67145e534/diff:/var/lib/docker/overlay2/54d4fe6d320e6d01134025b773d7838cd4e274bae034bdde53da053ae0aee723/diff:/var/lib/docker/overlay2/05c4910c8bb6b2ad05bb94fe3cf65787c78e6e9e38df95488900e77e362d6444/diff:/var/lib/docker/overlay2/154377cb1ad18cdfe44f17df60b06642ab7c1c799e69495ffe84a18d1bf7c496/diff",
"MergedDir": "/var/lib/docker/overlay2/5b47455a100e18ad5b4061e103e25bbb6a01668de7286325d4026504e0927bcf/merged",
"UpperDir": "/var/lib/docker/overlay2/5b47455a100e18ad5b4061e103e25bbb6a01668de7286325d4026504e0927bcf/diff",
"WorkDir": "/var/lib/docker/overlay2/5b47455a100e18ad5b4061e103e25bbb6a01668de7286325d4026504e0927bcf/work"
"Name": "overlay2"
"Mounts": [
"Type": "bind",
"Source": "/home/nako/pi-hole/etc-dnsmasq.d",
"Destination": "/etc/dnsmasq.d",
"Mode": "rw",
"RW": true,
"Propagation": "rprivate"
"Type": "bind",
"Source": "/home/nako/pi-hole/etc-pihole",
"Destination": "/etc/pihole",
"Mode": "rw",
"RW": true,
"Config": {
"Hostname": "42ee74fe7f2e",
"Domainname": "",
"User": "",
"AttachStdin": false,
"AttachStdout": false,
"AttachStderr": false,
"ExposedPorts": {
"443/tcp": {},
"53/tcp": {},
"53/udp": {},
"67/udp": {},
"80/tcp": {}
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"TZ=Europe/Madrid",
"DNS1=127.0.0.1",
"DNS2=1.1.1.1",
"PATH=/opt/pihole:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"ARCH=arm64",
"UBUNTU_SUITE=buster",
"DOCKER_REPO=multiarch/debian-debootstrap",
"PIHOLE_ARCH=arm64",
"S6OVERLAY_RELEASE=https://github.com/just-containers/s6-overlay/releases/download/v2.1.0.2/s6-overlay-aarch64.tar.gz",
"PIHOLE_INSTALL=/root/ph_install.sh",
"PHP_ENV_CONFIG=/etc/lighttpd/conf-enabled/15-fastcgi-php.conf",
"PHP_ERROR_LOG=/var/log/lighttpd/error.log",
"IPv6=True",
"S6_LOGGING=0",
"S6_KEEP_ENV=1",
"S6_BEHAVIOUR_IF_STAGE2_FAILS=2",
"ServerIP=0.0.0.0",
"FTL_CMD=no-daemon",
"DNSMASQ_USER=root",
"VERSION=v5.2.4"
"Cmd": null,
"Healthcheck": {
"Test": [
"CMD-SHELL",
"dig +norecurse +retry=0 @127.0.0.1 pi.hole || exit 1"
"Image": "pihole/pihole:latest",
"Volumes": {
"/etc/dnsmasq.d": {},
"/etc/pihole": {}
"WorkingDir": "",
"Entrypoint": [
"/s6-init"
"OnBuild": null,
"Labels": {
"com.docker.compose.config-hash": "e26033e425537a6274d5a384778ade49877ccf8759247263592e5dfd47ad70ac",
"com.docker.compose.container-number": "1",
"com.docker.compose.oneoff": "False",
"com.docker.compose.project": "pi-hole",
"com.docker.compose.project.config_files": "docker-compose.yml",
"com.docker.compose.project.working_dir": "/home/nako/pi-hole",
"com.docker.compose.service": "pihole",
"com.docker.compose.version": "1.25.0",
"image": "pihole/pihole:v5.2.4_arm64",
"maintainer": "adam@diginc.us",
"url": "https://www.github.com/pi-hole/docker-pi-hole"
"NetworkSettings": {
"Bridge": "",
"SandboxID": "78f5c6ae44df9ca485fc04dee58e86d4ab9116e7816b563fdd1b13ceec6dfb30",
"HairpinMode": false,
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"Ports": {
"443/tcp": [
"HostIp": "0.0.0.0",
"HostPort": "443"
"53/tcp": [
"HostPort": "53"
"53/udp": [
"HostPort": "53"
"67/udp": [
"HostPort": "67"
"80/tcp": [
"HostPort": "80"
"SandboxKey": "/var/run/docker/netns/78f5c6ae44df",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null,
"EndpointID": "",
"Gateway": "",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"MacAddress": "",
"Networks": {
"pi-hole_default": {
"IPAMConfig": null,
"Links": null,
"Aliases": [
"pihole",
"42ee74fe7f2e"
"NetworkID": "953e5b0d1b733f41115f1086c0e14f2d72abe428917060fde764c82b4e7877be",
"EndpointID": "370b54c4ca198127f15e7065b9545fce1becea2cdbbd361bb82e2f13bc1714ce",
"Gateway": "172.18.0.1",
"IPAddress": "172.18.0.2",
"IPPrefixLen": 16,
"IPv6Gateway": "",
"MacAddress": "02:42:ac:12:00:02",
"DriverOpts": null
