name resolution
resource (primary DNS server) not responding per pc - i have restarted dns server via pihole admin page, and also checked local IP which is currently correct
qy4oqhr072
please run the following on the node running Pi-Hole
dig flurry.com
dig flurry.com @9.9.9.9
then try the same from a device using pi-hole as its dns but swap the dig command for nslookup
in command prompt and paste the results here
jfb
May 21, 2019, 5:09pm
3
Your debug log shows a few problems with the Pi connecting to your network. This may be causing problems with clients being able to find the Pi-Hole.
[✗] No IPv4 address(es) found on the eth0 interface.
[✗] No IPv6 address(es) found on the eth0 interface.
[i] Default IPv4 gateway: 192.168.0.1
* Pinging 192.168.0.1...
[2019-05-21 09:01:43.546 26317] -> Unique clients: 2
What is the output of the following (will show the clients that have connected in the previous 24 hours). Check that all expected clients are here, although some may be going through your router and not showing as individual clients.
echo ">top-clients withzero (15)" | nc 127.0.0.1 4711
pi@raspberrypi:~ $ dig flurry.com
; <<>> DiG 9.10.3-P4-Raspbian <<>> flurry. com
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 61937
;flurry. com. IN A
flurry. com. 2 IN A 0.0.0.0
;; Query time: 0 msec
;; WHEN: Tue May 21 14:01:02 EDT 2019
;; MSG SIZE rcvd: 55
pi@raspberrypi:~ $ dig flurry.com @9.9.9.9
; <<>> DiG 9.10.3-P4-Raspbian <<>> flurry. com @9.9.9.9
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 18849
;; flags: qr rd ra; QUERY: 1, ANSWER: 3, AUTHORITY: 0, ADDITIONAL: 1
;flurry. com. IN A
flurry. com. 300 IN A 98.136.103.26
flurry. com. 300 IN A 74.6.136.153
flurry. com. 300 IN A 212.82.100.153
;; Query time: 89 msec
;; SERVER: 9.9.9.9#53(9.9.9.9)
;; WHEN: Tue May 21 14:01:18 EDT 2019
;; MSG SIZE rcvd: 87
pi@raspberrypi:~ $ echo ">top-clients withzero (15)" | nc 127.0.0.1 4711
0 6391 192.168.0.38
1 510 127.0.0.1 localhost
2 1 192.168.0.53 raspberrypi
---EOM---
pc:
Microsoft Windows [Version 10.0.17134.765]
(c) 2018 Microsoft Corporation. All rights reserved.
C:\Users\BEASTMODE>nslookup flurry.com
Server: rdns01.suddenlink.net
Address: 208.180.42.68
Non-authoritative answer:
Addresses: 212.82.100.153
74.6.136.153
98.136.103.26
C:\Users\BEASTMODE>nslookup flurry. com @9.9.9.9
*** Can't find server address for '@9.9.9.9':
Addresses: 98.136.103.26
74.6.136.153
212.82.100.153
jfb
May 21, 2019, 6:16pm
8
This shows that your PC is not using Pi-Hole for DNS - it is using the IP shown.
The format should be nslookup flurry.com 9.9.9.9
, without the "@". The formats for dig and nslookup are different in this regard.
C:\Users\BEASTMODE>nslookup flurry.com 9.9.9.9
Server: dns.quad9.net
Address: 9.9.9.9
74.6.136.153
98.136.103.26
jfb
May 21, 2019, 6:20pm
10
What is the IP address of the PC? One of these? If not, this is further confirmation that the PC isn't using Pi-Hole.
the .38 is my pc according to this...
C:\Users\BEASTMODE>ipconfig
Windows IP Configuration
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::25a0:3b9f:9692:87b1%7
IPv4 Address. . . . . . . . . . . : 192.168.0.38
Default Gateway . . . . . . . . . : 192.168.0.1
jfb
May 21, 2019, 6:54pm
12
Farther down in the ipconfig output it will show you the DNS server(s). What are they?
C:\Users\BEASTMODE>ipconfig /all
Host Name . . . . . . . . . . . . : DESKTOP-1HFSMEU
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Description . . . . . . . . . . . : Intel(R) I211 Gigabit Network Connection
Physical Address. . . . . . . . . : 0C-9D-92-82-34-41
Link-local IPv6 Address . . . . . : fe80::25a0:3b9f:9692:87b1%7(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.38(Preferred)
Lease Obtained. . . . . . . . . . : Tuesday, May 21, 2019 9:15:52 AM
Lease Expires . . . . . . . . . . : Wednesday, May 22, 2019 2:55:42 PM
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 34381202
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-7F-3C-1C-0C-9D-92-82-34-41
DNS Servers . . . . . . . . . . . : 192.168.0.53
jfb
May 21, 2019, 7:14pm
14
That is interesting. This shows that your DNS is Pi-Hole, but the nslookup went to a different DNS server. Run nslookup flurry.com
again from that PC and see if shows the same server it previously showed.
Is suddenlink related to your ISP?
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 192.168.0.53
Addresses: ::
0.0.0.0
jfb
May 21, 2019, 8:39pm
16
Did you resolve the Pi IP address problem noted in my first reply?
temporarily, reset pc, came back up, but it'll cut out here and there to where this was the error when troubleshooting
system
Closed
June 12, 2019, 11:46pm
19
