Pihole DNS doesn't crash
I'm getting random crashes of the DNS service. When it happens, I can log into the UI, restart DNS, and its fine. Until it crashes again. Sometimes it lasts a day, sometimes its an hour.
It's a little difficult to see what may be going on because it looks like the log files are being created new when you restart instead of continuing on:
Normally we'd see something about a shutdown or the end of the previous logging and then a new start up process. This looks like the entire device was restarted or the /var/log directory was wiped.
In testing, I had restarted it. Of course, its now been running without issue since then. Here's another token, but I assume you really need one after it dies?
Can you explain exactly what you did when you restarted it? Do you mean you restarted the whole device with a reboot?
Do you have your /var/log set up as a ramlog or anything that would wipe that directory?
Explanation for what I mean when I say the log was not complete. Normally we'd see some activity before the startup from the previous daemon that was running, like below:
dan@raspberrypi:/var/log $ cat pihole-FTL.log
[2021-06-19 19:06:00.534 668M] Shutting down...
[2021-06-19 19:06:00.785 668M] Finished final database update
[2021-06-19 19:06:00.785 668M] Waiting for threads to join
[2021-06-19 19:06:00.785 668M] Thread telnet-IPv4 (0) is idle, terminating it.
[2021-06-19 19:06:00.786 668M] Thread telnet-IPv6 (1) is idle, terminating it.
[2021-06-19 19:06:00.786 668M] Thread telnet-socket (2) is idle, terminating it.
[2021-06-19 19:06:00.786 668M] Thread database (3) is idle, terminating it.
[2021-06-19 19:06:00.786 668M] Thread housekeeper (4) is idle, terminating it.
[2021-06-19 19:06:00.787 668M] Thread DNS client (5) is idle, terminating it.
[2021-06-19 19:06:00.787 668M] All threads joined
[2021-06-19 19:06:00.797 668M] ########## FTL terminated after 48d 22h 1m 11s (code 0)! ##########
[2021-06-19 19:06:01.795 23734M] Using log file /var/log/pihole-FTL.log
[2021-06-19 19:06:01.795 23734M] ########## FTL started! ##########
[2021-06-19 19:06:01.795 23734M] FTL branch: master
[2021-06-19 19:06:01.795 23734M] FTL version: v5.8.1
[2021-06-19 19:06:01.795 23734M] FTL commit: b90ab8b1
[2021-06-19 19:06:01.795 23734M] FTL date: 2021-04-21 20:03:47 +0100
[2021-06-19 19:06:01.795 23734M] FTL user: pihole
[2021-06-19 19:06:01.795 23734M] Compiled for armv7hf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2021-06-19 19:06:01.795 23734M] Creating mutex
[2021-06-19 19:06:01.797 23734M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
If it crashed then we'd expect to see something that didn't say "Shutting down", just the tail of the previous logging and then a new start, like below (just an example, ignore the timestamps since I copy/pasted from a couple of different sections to make this look like a crash):
