If I click on "Disable for 5 minutes" not only the blacklist gets disabled, but the whole ftl gets disabled,
and enabling again using the webinterface fails as well.
The only solution is "sudo reboot"
dns should keep working, only blocked sites should not be blocked for the specified time
Internet stops working because of DNS failure
https://tricorder.pi-hole.net/tm136y38gr
Some screenshots
