_[Replace this text with what you think should be happening. Please include as much detail as possible including, but not limited to:
-operating system
ubuntu 18.04
-hardware]
odroid
When I stop pihole on my ubuntu, I have no more dns on my ubuntu.
It works when I put the dns server in /etc/resolv.conf but it's not permanent.
What can I do ?
So, you installed pi-hole on Ubuntu and pointed the dns entries of Ubuntu to pi-hole and then stopped pi-hole and where wondering why it was not working any longer?
Either don't stop pi-hole or point the dns of Ubuntu to some other dns server.
no, i installed pihole on my odroid, i doesnt touch anything to the dns entries of my odroid.
Now, when i stop pihole on my odroid, the dns resolution doesn't work anymore.
It works when pihole is on.
It works, when pihole is stopped, when I add 1.1.1.1 for example in /etc/resolv.conf, but it's ephemeral...
Well, just as others have said before:
For Pi-hole to be effective, it has to be your local DNS server.
If you stop Pi-hole, DNS resolution will stop.
That's just the way it is.
But I am just restating the obvious.
Maybe we haven't understood your problem yet.
Could you try to explain what you are trying to achieve, and especially why you would want to switch off Pi-hole at all?
