Thats correct, im sorry for not including that.
Im running it on Proxmox>VM:UbuntuServer>Docker>Portainer
"categories": [
"Other",
"Tools"
"description": "A Linux network-level advertisement and Internet tracker blocking application which acts as a DNS sinkhole.",
"image": "pihole/pihole:latest",
"logo": "https://raw.githubusercontent.com/SelfhostedPro/selfhosted_templates/master/Images/pihole.png",
"name": "pihole",
"note": "When the installation is complete, navigate to your.ip.goes.here:1010/admin. Follow the article \u003ca href='https://medium.com/@niktrix/getting-rid-of-systemd-resolved-consuming-port-53-605f0234f32f'\u003ehere\u003c/a\u003e if you run into issues binding to port 53.",
"platform": "linux",
"ports": [
"53:53/tcp",
"53:53/udp",
"67:67/udp",
"1010:80/tcp",
"4443:443/tcp"
"restart_policy": "unless-stopped",
"title": "Pi-Hole",
"type": 1,
"volumes": [
"bind": "/portainer/Files/AppData/Config/PiHole",
"container": "/etc/pihole"
"bind": "/portainer/Files/AppData/Config/PiHole/DNS",
"container": "/etc/dnsmasq.d"
