Ok so I have a weird one... I made a fresh install of resbian & installed pihole on it.
I set my router to use 192.168.0.100 as DNS server, it's the static local IP of my pihole DNS server. On one Windows desktop and on my GF's iPad, sometimes, Internet doesn't work. For example, facebook.com or google.com is no longer resolving, and pinging 8.8.8.8 doesn't work neither.
ping
example on the Windows desktop: > ping google.ca -tPinging google.ca [172.217.1.163] with 32 bytes of data: - Pastebin.com -
content here: ---= Detecting Installed Package Versions:Pi-hole: v3.1.4 (master:v3.1.4-0 - Pastebin.com - Setting page screenshot: https://i.imgur.com/ZWxDnnX.png
- Router setting screenshot: https://i.imgur.com/mn0lBOg.png
As soon as I disable pihole, it stats working back. If I remove pihole DNS server from the router setting, it starts working back.
Any help would be highly appreciated!
Edit: sometimes I also just get:
> ping google.ca -t
Ping request could not find host google.ca. Please check the name and try again.
Edit2: I just removed the pihole from the DNS server settings on my router and I still have the same issue on the Windows machine...
