When you disable Pi-hole, it clears all blocking and blocks nothing. We are not aware of a bug in this area.
Where are you seeing that Pi-hole is blocking domains when it is disabled? Is this in the Pi-hole query log, in the dnsmasq log at /var/log/pihole.log, etc.?
When i disable pihole, pihole still block ads and sites like analytics.google.com
And if i add analytics.google.com into whitelist it is still unreachedable, stay blocked.
In firefox if i go to analytics.google.com get me "Unable to connect"
other test (with pihole disabled) is as follow
dig analytics.google.com
analytics.google.com. 1 IN A 0.0.0.17
;; ADDITIONAL SECTION:
info.portmaster. 0 IN TXT "blocked: analytics.google.com. in activated lists PL-B,SB-AM and in deactivated lists BYX, DCT"
info.portmaster. 0 IN TXT "analytics.google.com. is blocked by filter lists PL-B, SB-AM"
info.portmaster. 0 IN TXT "analytics.google.com. would be blocked by filter lists BYX, DCT"
;; Query time: 20 msec
;; SERVER: 10.0.0.99#53(10.0.0.99)
;; WHEN: Sat Jan 22 20:33:15 CET 2022
;; MSG SIZE rcvd: 375
I notice another strange behaviour.
I have one domain in blacklist, and when i disable pihole this domain isn't blocked, and when i enable pihole blacklisted domain is blocked.
I don't understand where is problem but there is!
It Is possible that unbound dns in opnsense cause trouble?
Pihole DNS setting use opnsense as upstream server..
Looking at this: do you run portmaster? Do you use any filterlist with that software. This is a response not generated by Pi-hole. Your issue is upstream.
damn damn damn damn, i completly forgot of portmaster (safing.io/portmaster/) a software that a test a couple of days ago. This software block something..
After removing portmaster all working as expected.
