Disable and Enable button not working in web interface
I can disable and enable via SSH. When I disabled via SSH, I tried to enable from the web interface and get the same half circle turn and nothing.
w0vzpg0n9m
jfb
2
You are running the DietPi distribution of Pi-hole. Please contact them for support.
Their distribution is different in some respects than the pi-hole.net distribution.
Your problem may be related to this message in your debug log:
-rw-r--r-- 1 www-data www-data 988 Apr 8 21:58 /var/log/lighttpd/error.log
2020-04-08 21:51:14: Wrong token! Please re-login on the Pi-hole dashboard.
Thank you! I appreciate it.
system
Closed
6
