Pi-hole Version v3.1.4 Web Interface Version v3.1 FTL Version v2.10
set DHCP for multiple networks at home.
Only see option on GUI to set for 1 network
smuia2xpf8
Mcat12
September 20, 2017, 9:14pm
2
What do you mean by multiple networks? Multiple subnets? We don't support all of dnsmasq's DHCP feature set via the web interface, so you might have to set that up yourself via dnsmasq config files.
I mean, subnets, like 192.168.0.0 network, the. Another in the 10 network. If it cannot be done in the GUI, does it work the same in the command line?
Mcat12
September 20, 2017, 10:34pm
4
You would probably have to have one network interface on both subnets, and then research more about dnsmasq's DHCP options.
